Throttle Junkie35
Maybe one of the mods can clean that up to avoid confusion.
			A couple of bucks
There is an 8bvfa helix in this secondary that works well too. I'm running one on my 600 twin.
http://www.ebay.com/ulk/itm/171991860557
8bvfa is a Yamaha helix that measures 48/42.
							Sgtlange
Not a bad price on that ebay item. Would the secondary fit on my vmax as an assembly? Or just the Helix would work?
			yamahamark
Not positive but I don't think it will. I think shafts are different
			I have been reading this thread and was wodering if this would work on the 500 twin as well. Not the clutching but reed stop notch and such. Thanks guys
			yamahamark
Yes it will work with the 500.
			01sxr700
I don't know, I went and reread the reed notch instructions and it seemed pretty straight forward to me. Says that it "unblock the intake port for a straighter flow into the case on the top side of the reed stopper" which is what it does.
			Sgtlange
easy mod to do, doesn't hurt to try! But I do believe it says 500/600. Like I said I plan to have this done by xmas so i'll report back the difference in response when I get it done.
			Sgtlange
Yeah I saw that. Appreciate you finding the other two items, the sellers still have them so I should have a few of the parts soon.
Throttle Junkie35
That center reed flows into the boost port which goes to the clyinder, not the case.I don't know, I went and reread the reed notch instructions and it seemed pretty straight forward to me. Says that it "unblock the intake port for a straighter flow into the case on the top side of the reed stopper" which is what it does.
yamahamark
No problem sgtlange when you get it all together you will notice a big change in throttle response and performance in that little 600 twin.
I know i did.
Also a lot better fuel economy.
			I know i did.
Sgtlange
Could anyone explain a little more on the 8ab weights? Are these stock or aftermarket? It seems a lot of Yamaha parts start with 8ab.
			A couple of bucks
The 8ab prefix is year specific.
8ab is 199?
8ca is 199?
8cr is 199?
And etc etc etc
The 8ab, 8ca & 8bu-00 all have the same profile. They just differ in weight.
http://www.totallyamaha.com/snowmobiles/aaTECH/drivespecs/clutch_parts1.htm
http://www.totallyamaha.com/snowmobiles/aaTECH/drivespecs/clutch_parts2.htm
8ab = 41.0 grams
8ca = 42.8 grams
8bu-00= heavier yet. Can't remember exactly.
			8ab is 199?
8ca is 199?
8cr is 199?
And etc etc etc
8ab = 41.0 grams
8ca = 42.8 grams
							A couple of bucks
https://partstream.arinet.com/Mobil...EQs6sU__gAgJIYbuXDNhtmLIOk-ySNDjvWkMj3M1.html
I'm not quite sure what came in yours. It shows 3 different weights.
Sgtlange
Ah, makes sense. I found some from Hauck Performance i'll order since i'm not sure what's in mine
			A couple of bucks
You might be able to read the stamping on them while they are still installed. Just need a flashlight.
		super1c
Super Moderator
http://www.totallyamaha.net/threads/69770-quick-question-about-reed-notch   In case anyone was wondering here is the info i found when i did my viper reed cages in a twin.   Post #10 by betheviper.
http://www.totallyamaha.net/threads/57103-Need-help-with-600-twin-clutching The clucthing tread i got my info from turk and daman.
A couple of bucks
Two years ago I put viper cages w/ the stock OEM reeds in an 01 SXR 500. I replaced the stock galvanized stops w/ stainless and ground out a mild notch. Good night nelly what a difference that made. Almost like a mini supercharger. Spark plug color lightened up too.http://www.totallyamaha.net/threads/69770-quick-question-about-reed-notch In case anyone was wondering here is the info i found when i did my viper reed cages in a twin. Post #10 by betheviper.
Sgtlange
So excited to do these two mods!! Now we just need another snow storm like last week
