Sgtlange
Mabey a spacer off of the reverse linkage??
https://partstream.arinet.com/Mobil...Us8fRVzD5ugISNIk9UIeucyrNHf7thdGiqUHNSA1.html
Bingo! You're the man ��
yamahamark
Sled looks clean. Another good upgrade is a set of plastic ski's.
Also an upgrade for looks is to get some aircraft paint remover and strip the paint off the tunnel and then buff it so it shines.
Sgtlange
Definitely plastic skis are on the list. Here's a few more pics.. Clean is reason I decided to pick it up. Only typical wear maintenance was needed especially the track I didn't look at it good enough when I bought it cause I should have talked him down in price a bit cause it was shot.Sled looks clean. Another good upgrade is a set of plastic ski's.
Sent from my ONE A2005 using Tapatalk
yamahamark
Your sled is cleaner than mine was when I picked it up.
Those ski's look pretty good hard to find a set for $65 that looks good.
yamahamark
If you decide not to get those keep in mind that Polaris ski's are a direct bolt on.
A couple of bucks
White Poo Grippers would look super on yours Mark.Polaris ski's are a direct bolt on.
yamahamark
They would look great. Right now I have a set of slp chrome molly ultra-lites on mine. I got them real cheap (FREE) off my dads ultra sks before he sold it.
Sgtlange
Picked this up again today. Quick question - I bought the vforce reeds and was planning to do the reed notch mod. I see the vForce are a bit different than stock. Since I have these reeds now do I still do the notch? The vForce have only two screws and what looks like they're own stopper. Is this right? Do I still use the stock stopper? Thanks
super1c
Super Moderator
If you bought v-force reeds stick with the v-force stuff. They should have come with a spacer which will in effect do the same as the stopper notch.
super1c
Super Moderator
Just asking, how come you went with v- force instead of the viper reeds?
Sgtlange
They are vForce out of a viper not the same thing?
super1c
Super Moderator
Nope. V force reeds are a aftermarket Reed. But all things being equal they should work. You can't do the stopper notch on those cages but they should have come with spacers which will achieve same result. Do you have a pick of the Reed cages you bought for confirmation?
Sgtlange
This is what I got not sure if I have the spacer I picked them up off another ty user
Sgtlange
If anything I already did the stock cage mod so I can throw those back in if you think the performance will be better
super1c
Super Moderator
Yup those are v force reeds. A aftermarket Reed cage. The big thick block in your pick apears to be the spacer. I would run those v force ones. Should achieve same result as the viper ones with notch. Make sure you use copper spray when putting back together if not using new gaskets.
Sgtlange
Pic side by side. They're definitely thicker. Does high tack achieve the same result as copper spray? Not familiar with copper spray.
A couple of bucks
They both work well. Copper Coat works better on metal to metal that has flaws on the mating surface.
super1c
Super Moderator
Not sure about high tach, never seen it. Copper spray is a high temp gasket sealer. The v force cages will work perfect. No mods to them needed. Google permatex copper spray gasket so you know what I'm referring to then compare.
