It started at the end of last season. When starting from standstill it's a clunking noice but once in motion everything works fine and it shifts as it should. If I'm in motion and give full throttle it's not there, only from standstill.
I tightened the chain as per instructions in the manual but it didn't help. If I grip the secondary clutch and twist, it feels tight, it's not moving coaxially like when a bearing is worn. However in radial there's a huge slack. If I turn it and look on the side where the chain housing is, the brake disc can rotate almost 10 degrees before I meet any resistance, should it be like this? Even if the chain and sprockets are worn i can't imagine it would be such a gigantic slack. It''s 3000 miles since brand new so the sled hasn't been used much.
