checkinpox
Just gotta wait for the snow. Getting pretty antsy lol
Sent from my SM-G935W8 using Tapatalk
Vincent
Well-known member
We had about 5 to 6 in. of snow already. Bunch of sleds already drove around town. But the weather network is announcing +4 to +6c with rain this week. So its as good as gone. But for now my area looks like winter.
checkinpox
I have zero. Feels like early fall.
Sgtlange
Check out this thread: http://www.totallyamaha.net/forums/...600-Twin-Looking-for-better-throttle-response
I've got the same exact sled except a '98 and followed the recommendations and it made a HUGE difference. I think the clutching was the biggest help.
A couple of bucks
Sargent , how's she running?? You get those gears in?
checkinpox
Only thing I didn't do was the clutching. My wife rides it mostly on the trail. So I'm gonna see how she likes it now and adjust from there. Did the head gasket and add vforce reeds which should do the same as the stopper notch. Plus the track.
A couple of bucks
Be prepared to add some weight to the tips. I'm thinking 7700 RPMs is what your shooting for.
A couple of bucks
Sgtlange
Did not do the gears yet. She's running good now that I fixed the reed issue last year. Just pulled it out of the trailer and into the garage to start prepping for this season. Plan to do much more riding only put 100 miles on it last year. We got a place up north now going to be riding the Higgins lake area heavily. You think gearing it down will make a big difference? I may do that this year if I can find the gears. Also looking for plastic skis. Any thoughts where I can find vForce reed petals for those viper cages?
A couple of bucks
I thought I sent you a top gear? Or did you put them in a safe place and ya can't remember where that safe place is?
Sgtlange
haha you're right, been a year :P. It's in my parts bin. I didn't put it on last year as I already had the case back together. But looks like i'll be tearing into it now!
A couple of bucks
I cannot remember what top I sent you. What all do you have available.
Sgtlange
I've got a 21 tooth gear. Need to order the chain yet.
Vincent
Well-known member
That should make a big difference compared to the stock 23 tooth gear. It's crazy how over gear the 600 twins were!
A couple of bucks
http://www.totallyamaha.net/forums/...-better-throttle-response?p=702016#post702016Need to order the chain yet.
checkinpox
So ran the sled today... Track hooked up awesome. But I still have a bad mid range gurgle. Idles great, and cleans up above 6k rpm. Guess I'll dig into the carbs and check where my needles are at...
super1c
Super Moderator
I didnt read through entire post, its late and im tired! LOL! Did you do the reed stopper notch or reed spacers. They should clean up the mid range gurgle
checkinpox
Has vforce 3's. And thinned had gasket. Rest is factory.
sgauthier
FYI. If I recall those stock 600 twins are prone to ring pins failing and rings spinning causing them to catch the exhaust ports. Hope you don't have any problems but with that low mileage I'm wondering if it ever has had the updated Pistons installed. Sled looks good, good luck.
checkinpox
Sled original owner was the wife of the local Yamaha dealer, I would hope that its been updated. Pistons looked good when I had the head off.
