I almost don't want to say this with for concerns of not being believed, but our "98" XTC 500 has gone 102 mph on the speedo in dream low resistance conditions with it's current 20/39 gears. Have seen 87mph on 1,000 foot radar run, and also see 96 mph on the speedo regularly on normal very good hardpack. This sled currently has over 10,000 miles on it without a rebuild. (I know, it is on borrowed time and needs to be done), but it just doesn't get ridden that often anymore. The only mods are reed stopper, clutching , & gearing. I guess my point is that these things come geared too high from the factory and if the RPMs are dialed in correctly after regearing the top speed will not be limited by even the lower gearing than stock that I have. Judging by the difference between the speedo and radar in the 1,000 foot run a few years ago I believe my indicated 102 was really more like a real 92 to 93. (The the radar 87mph indicated 96mph). With my gearing that calculates out to about a 5% overdrive which is theoretically possible. The 96mph we see calculates out to a 1 to 1 ratio. Ours accelerates harder when the rpms are in the 7600 to 7800 range but it likes to wind out to 8000 rpm on the top. I would definitely continue to look at things other that gearing.
