Roushrider81
- Dec 4, 2005
Right now stock the gears are top= 22 and bottom=39
if i went to a top=20 bottom=42
would i need a dif. chain or a new chain case?????
yamaholic22
why on earth would you want to go that low on gearing? 200 foot race? 166" track?
bluehammer
Same chain, same gear case. The problem you will have though is that with the wider lower gear and the smaller top, you won't have many teeth in the chain on the top gear. If you have good traction, the top gear could fail if the track didn't spin some. Not likely, but could.
Roushrider81
- Dec 4, 2005
that is what a hi-tech performance reccommened and the guy that i bout the clutch from said the same
yamaholic22
what sled are you going to be running this on?
n2oiroc
yamaholic22 said:why on earth would you want to go that low on gearing? 200 foot race? 166" track?
now thats funny! lol!
ModMMax
I run 20/42 with 9 tooth drivers in my mountain sled. I have never heard of a 20 or 19 tooth gear failing but I have heard of 18's breaking. The 70 link chain will work with 20/42.
Roushrider81
- Dec 4, 2005
i am running a 2000 v-max 700 deluxe and i got AAEN pipes and E.R. kit from www.hitechperformance.com and their speed ring.
yamaholic22
what are you running for a track and studs? That is VERY low gearing for just general trail riding, you will probably find a nice overrev on top end with gearing that low in most conditions, and if you don't have good traction it will dig a trench to china on holeshots.
2001_blue_sxr
- Oct 20, 2005
- New Liskeard, Ontario, Canada
- www.vanducchiracing.com
i went to a 21/40, and its aggressive enough for my taste...ripsaw and transfer rods cant hardly handle it...
yamaholic22
2001_blue_sxr said:i went to a 21/40, and its aggressive enough for my taste...ripsaw and transfer rods cant hardly handle it...
exactly, that is MUCH closer to what i believe they should be run at, even 22/40.
2001_blue_sxr
- Oct 20, 2005
yamaholic22 said:exactly, that is MUCH closer to what i believe they should be run at, even 22/40.
if i woulda kept stock chain i woulda, but a) the stock chain was umm, worn out with 12000kms on it, so i swapped for 15wide instead of the stock 13wide...
Roushrider81
- Dec 4, 2005
could i blow the engine over reving?
2001_blue_sxr
- Oct 20, 2005
if it overrevs constantly yes
yamaholic22
Roushrider81 said:could i blow the engine over reving?
Yes, and besides that you are losing horsepower by overrevving anything over 8600 or so.
2001_blue_sxr
- Oct 20, 2005
yamaholic22 said:Yes, and besides that you are losing horsepower by overrevving anything over 8600 or so.
depends...AAEN's pipes recommend 9100 peak RPM...
Roushrider81
- Dec 4, 2005
well my pipes came in TODAY!!!!!!!!!!!
2001_blue_sxr
- Oct 20, 2005
what did you get??
Roushrider81
- Dec 4, 2005
AAEN's triple pipes, the clutch spring and weights, i also have the E.R. kit for the Secondary from Hi tech performance as well as there speed ring for the primary
2001_blue_sxr
- Oct 20, 2005
sweet, you'll love the aaens, i know i do
