V-Max 600SX races at idle, bogging PART TWO PROBLEM FOUND
I`m in the need of more attention so I started a new thread with some more "consistent" facts.
Previous thread: http://www.totallyamaha.net/forums/showthread.php?t=18448
I`m working on a 1997 V-Max 600 SX for a friend, the problem is that it races on idle, from 2000rpm to 2500rpm, then when you hit the throttle it starts bogging when the primary engages (maybe just before it engages).
The sled will move forward slowly but when you get the rews above 5500rpm or so, it rews like hell and pulls strong.
I took the carbs off and cleaned them, looked good though. Know I have the carbs off again because the last time I didn`t remove the air screws due to a missing screwdriver in my workshop, so I took the carbs off again and removed the air jets, they were all clean.
Reeds looks fine, no broken blades, checked them visually without removing the inlet boots, also tryed pushing the blades with my fingers and they seemed fine.
I tried spraying CRC 5-56 (universal lubricant, I couldn`t find the can with starter fluid) around the crankseal PTO side , I also tried spraying around the inlet boots/carbs but I could not hear any differnce on the engine idle. I did not try so spray around the magneto side crankseal, I somehow forgot.
I will get a can with real starte fluid and do it again, will I reach the magneto side seal without removing anything?.
Since I have the carbs off now I checked the air/gas screw settings.
One screw was 2 turns out and the other one was around 1 and 6/8 turns out.
I remember on my moped when I fiddled with the air/gas screw, if I turned it too much out the engine would idle high and the throttle response was kind of boggish, when I turned the screw too much in the engine died.
Could the air/gas screws be to far out on the V-Max engine?.
Gees I feel like a dork, my friend hasn`t ridden the sled since she bought it, she brought me with her as a "technical expert" (hehe) so that she would know that she didn`t buy any crap. The sled seemed fine when I rode it into the trailer three months ago, but a month ago when I was going to ride the sled from my friend to my house (had been sitting since we bought it) it was hard to start, and when I finally got it running it had the symptoms described above.
Gees I`m clueless.. or what it`s called.. .
I know it might be stupid to start two threads about the same sled but I just felt that I needed to, sorry
Joakim.
Joakim.
