As I wrenched, it started snowing outside!
(it`s raining outside now.. gees).
Anyway, everything went fine.
I pulled about 12-15 times before the engine started, guess it takes some time to fill up the empty float bowls.
The engine sounded healthy and ran MUCH nicer now. Just after it started I loosened the air bled screw on the oil pump. Came some oil out and I then tightened it.
I rode 1km with the sled, then I put some more gas in the tank (10liters, with 0.5% oil in it). I took a pen and marked the oil level on the oil tank. I then rode 8 kilometers with the sled and checked that the engine had used some oil, which it had, the level was about 1,5cm under the pen mark on the tank, so I guess the oil mixturing system is working.
The sled idles fine and there is no hesitation what so ever, so it clearly was the mag side seal that was my problem.
One thing I wonder , is if there is enough coolant in the engine. I put about 2,5 liters in it, I squeezed the hoses to get the air out. I also loosened the bled screw on the cylinder head while the sled was running. The coolant level in the expansion tank was a little over "full" after the ride. I checked that the coolers under foot boards got warm, which they did.
How can I be sure that I don`t have air in the system?. Remember that a girl will be riding this sled, and shes not that familiar with this kind of stuff, hehe.
I just went out to fire up the sled, it started on 1st pull, without choke, been sitting for 4 hours, so I think that`s good.
Oh another thing I wonder is if there is a drain plug for the oil in the chain case?.
I asked about this before and I was told that there was a drain plug, put I can`t seem to find it. There are two tiny holes in the plastic under the chain case, the holes are only about 5mm wide, so it would be impossible to reach or handle a drain plug from those holes.
?. The oil in the chaincase was really thick and white, (saw it on the dipstick).
Should the chain tensioner be "finger tight" ?. I turned the tightener bolt in so that it just hit the tensioner and I then tightened the lock nut.
Is it normal that the chain case gets a little warm after riding?.
Well guys that`s all for today.
Thanks so much for all the help, I couldn`t have done this without you guys !
Joakim.
