EricMichael
anyone know if a 2001 sxr set up correctly will beat a 2000 xc 600 with clutch kit/reeds/can?
xsivhp
should, pretty easily.
EricMichael
in 500ft i meant***with right set up
SNOWRULES
i would say no problem even if you were bone stock
n2oiroc
ill go against the flow here and say the xc will be the winner, espically in a short race. those genII 600 twins were fast 600's! 115.8 hp @ 7900 rpm's w/ 77 lbs/torque and lighter weight too! they were also low and the chassis had low rolling resistance, so good top end for a twin. i'd hate to say it, but i think my 03 pro x 700 and attak would be a close run to 60mph.
xsivhp
I think if all the mods were done to the sxr (head gasket, geared down, silencer drilled out, and clutched and jetted) I think it wouldn't be close at all.
Been der dun dat. If the 600 is a powervalve motor your gonna need pipes. Done that race a lot of times. Them powervalve 600,s really fly. You might get him on a very long top end run without pipes.
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
I'd put my money on the XC.
n2oiroc
hey shortstop, you figure out what motor mounts to get yet for your pro x?shortstop20 said:I'd put my money on the XC.
shortstop20
- Mar 6, 2005
Yep, I got them in the mail yesterday. About $40 for a set of 4 90 Duro motor mounts.
cacsrx1
shortstop20 said:Yep, I got them in the mail yesterday. About $40 for a set of 4 90 Duro motor mounts.
It hasnt snowed and your allready having grief?
shortstop20
- Mar 6, 2005
cacsrx1 said:It hasnt snowed and your allready having grief?![]()
No grief. Pulled my motor. I'm going to send it to Indy Specialty in Shakopee to get the PTO wide bearing upgrade, cheap insurance IMO. Going to replace the motor mounts while I'm at it as the stock 65 Duro mounts don't hold that 800 in there worth a crap.
cacsrx1
Just as well get it ported to.
jr_amsoil
crago you know what i should put the needles at in my carbs on my sled
hauck told me to put a 152 and two 150's for mains and leave pilots at 45
i am not sure where to put the needles
shortstop20
- Mar 6, 2005
I was thinking about it, but they want $500 to port it and they said it's only worth about 5 HP. $100 per HP......I'll pass. Next year I might buy some twin pipes for it.
I'm going to ride it this year with the 144", clutch it, and gear it in the 2.0 range and see how I like it before I invest in more HP.
n2oiroc
did you do the 144" yet? me want pics!shortstop20 said:I was thinking about it, but they want $500 to port it and they said it's only worth about 5 HP. $100 per HP......I'll pass. Next year I might buy some twin pipes for it.I'm going to ride it this year with the 144", clutch it, and gear it in the 2.0 range and see how I like it before I invest in more HP.
cacsrx1
jr_amsoil said:crago you know what i should put the needles at in my carbs on my sled
Stock position, but if U dont go to work, U wont need to worry about jetting.
shortstop20
- Mar 6, 2005
n2oiroc said:did you do the 144" yet? me want pics!![]()
Nope not yet. I was waiting for you to do yours so I could see pics.
Seriously though, I'm going to be ordering mine pretty soon. I'll be sure to post some pics.jr_amsoil
cacsrx1 said:Stock position, but if U dont go to work, U wont need to worry about jetting.![]()
School just started now so i ant working much but after school for a couple hours but i took out a big student loan i'll be ok.
n2oiroc
are you going with tracks usa stuff? i will with the rail extensions, but im torn between the slp and tracks usa tunnel extension. i wish there were some decent pics of each around.shortstop20 said:Nope not yet. I was waiting for you to do yours so I could see pics.Seriously though, I'm going to be ordering mine pretty soon. I'll be sure to post some pics.
