I'll take WHATEVER suggestions you have.. i have a 440 .030 over with 12 1/2 to 1 pistons.. stock crank and sportsman mopar rods.. its a muscle motors shortblock. The heads are indy 440-1 kit with the optional 325cc cnc job.. I have a holley dominator 1050 carb.. crane 688821 cam with roller lifters and tti headers. i also have a 1969 440 block .030 over that i want to make a 535 stroker motor out of BUT i need to get the BIG heads from indy because the lift is around 630 with the crane cam.. i want to get a lunati stroker motor cam and a jesel belt drive timing chain for the stroker motor.. the lunati is around 719 lift and i have to put different valve springs to make the indy heads I got work!!! Thats why I need another set of indy heads!!! The weight thing I can correct with lexan windows,,,but,,, the interior is STAINLESS instead of aluminum and the firewall is also stainless (bought it that way) so,,, i could do some major cosmetic work in the interior BUT,, I'd rather spend a zillion dollars with a callies crank and a set of BEAUTIFUL rods>>>> any suggestions???? Thanks Gary Oles nosboy
