stator problem
Fortress, I agree with MRVIPER700, I am a 23 year electrician in the navy and electrical componets can test out fine with a meter but they will break down when actual voltage or current is sent threw. I have seen it many times!!! I also had stator issues with one of my older VMaxs few years ago, I would also check the wiring as yamahahauler suggested, I heard of the wiring harness issues and did that fix and never had any issues! Good luck!
GS438
- Dec 28, 2004
Listen to MRVIPER the man knows what he's talking about!!!!!!!!!!!!!!!!!!!
fortress
GS438 said:Listen to MRVIPER the man knows what he's talking about!!!!!!!!!!!!!!!!!!!
yes, i'll try what he said,, i'm waiting the snow!! it was raining here yesterday and almost all the snow is gone
Exciterfan
I have also seen a broken reed petal result in really gutless acceleration but you could "feather" the throttle to eventually get the RPMs up. Have you checked your reed valves??
fortress
WELL WELL WELL
would you beleive this??
So, i did take the sled for a ride today for testing what mRviper was saying!!
WELL WELL WELL... the sled did work now!! WTF?? i didnt touch anything!! the sled doenst work since last year, we did open the engine, and found nothing!! SO, its was my second ride and it work now!!! Shit!! THat sled drive me crazy!
i still have no working handwarmer!!
but the sled work! yes it work!!
Mr freakin Viper that is all I have to say!!!!!!!!!LOL unreal
fortress
chadg said:Mr freakin Viper that is all I have to say!!!!!!!!!LOL unreal
i didnt even had the chance to test what MRViper was talking.. the sled did ride ok at first!!! humm
SRXtrafast
If fine now it's the Wire Harness under pipes
fortress
SRXtrafast said:If fine now it's the Wire Harness under pipes
nope, if you read the entire story, its not!
SRXtrafast
If you didn't touch anything you might be in for some more problems later,but glad it's running for you for the time being.
hahahhahahha the sled doesnt work no more mmmmm thats not a good christmass gift ......well ill wait for some news ...
CDI boxs - change it!
fortress,
Had an '83 VMAX 570 that did this same thing. It would run good sometimes, other times is would run rough or not at all. It wouldn't run at all below 12 degrees F. I took the CDI box out and tested it several times. Each time it would test out ok and then I would put it back in. I finally got VERY frustrated and just went and bought a new CDI even though I was sure it wasn't the CDI and didn't want to spend the $$$ to get a new one.
Well low and behold it was the CDI. The sled ran great after changing it out. So, now I am of the belief taht if you have a problem that you can't find after checking and rechecking everything, it is most likely an electrical problem and the CDI box is going to be my first try next time something like that happens again.
Mills
fortress,
Mills
