Well finally got the beast home.Got some work ahead of me.Sled needs to be cleaned up a bit.Looks like one ski needs alignment.Took it out for a few minutes and what a different feeling sled.Pin it and wow front pops up and she shoots like a bat out of hell.Actually stood on the back boards and wheelrd it 3 feet..that is crazy.Will have to play with the transfer rods.Will check track tension,one boogie wheel is chipped so I got my old ones from my 600 I can use.Guy told me he was only using regular gas in it,ican use midgrade or should I just stick to premium.Belt riding a bit low in secondary,will check that.Need to take clutches out and clean.Will put my 15.6(new) rollers in and takr the old ones out.He said it is bone stock..clutching...and jets are stock.Sled came from Minnisota,so elevation is not really different.right.Will check steering rods for any bend in them and front end bushings.Track is stock with picks,still looks not to bad.Anyways really had not any chance to look at it closely.Came home..ate supper and typing this.I am going into the garage for a while to look things over.Will come back on here later.Here are some picks.
