from what you are showing me if the gaps are with you on the sled, you need to either increase rear spring preasure, decrease center spring preasure or increase front ski pressure. These are the three things that will bring the gap up. As for the rear of the track being off the ground lifted or at rest without driver on it, this has is a side effect of the geometry of this skid, the transfer rods just wont let the skid drop down enough. If you want it to have a flat look while its sitting you will have to pull up the limiter strap. this of coarse lessens travel so I try to avoid it
