Diceman
Hey, check your personal messages!!! Thanks DicemanSRXer said:Hey Diceman, I am a short sled ride from you, and have all this week off, you could ride over and I could check it out for you if you like. Let me know, cause other than that, I plan on a big mileage week from home. 4 ft of fresh powder in the Bruce! PM me if you need a hand.
akrievins
Umm,
Didn't see this mentioned yet.
When I start my Viper from cold while on the stand the track will spin when I have the choke on half. The rpms are up when the choke is on, so that has to be why. After I take the choke off, it spins until the engine rpm is at 1500-1800. Then it will creep along. The only thing different, is that after it's warm and sitting at idle, the track won't spin. This is just normal, but in your case, it shouldn't be really be spinning after warm. Does the sled move on the ground after warmed up at idle?
Diceman
No it does not move on the ground....First I would like to thank everyone who replied to my problem especially Damon and SXRer( we should go for a spin some night ) ......I replaced the 3 bolts off the back of the secondary and the belt squealing has stopped completely and the track is no longer turning on the stand....just went for a rip and it seems fine...last question is should I try to add a washer to each bolt ??I put no washers on the new bolts...Does it matter??? Dicemanakrievins said:Umm,
bolin22
the washers should be added after the belt has some miles on it and the deflection changes.
With a new belt u probobly wont need any washers, how far down in the
secondary is the belt riding a little a lot???
Diceman
Not alot....well not sure what alot would be....not even 1?4 of an inch..you do mean when the sled is off right...l..I am trying to learn...loldaman said:With a new belt u probobly wont need any washers, how far down in the
Yes off,,it sounds like it's good to go
Concept Carbon
Diceman said:No it does not move on the ground....First I would like to thank everyone who replied to my problem especially Damon and SXRer( we should go for a spin some night ) ......I replaced the 3 bolts off the back of the secondary and the belt squealing has stopped completely and the track is no longer turning on the stand....just went for a rip and it seems fine...last question is should I try to add a washer to each bolt ??I put no washers on the new bolts...Does it matter??? Diceman
what am i chop liver
, who's the one who told you to change the bolts way back. lol, just joking glad to hear everything worked out.
Diceman
Hey you are right...thanks too....hoping all is well for the vmax...really want to hit the 3000 k for this season...DicemanConcept Carbon said:what am i chop liver, who's the one who told you to change the bolts way back.
lol, just joking glad to hear everything worked out.![]()
LOLConcept Carbon said:what am i chop liver, who's the one who told you to change the bolts way back.
