Sno_Racer_Xtreme
i thought i was goin to have to take my sled to a mechanic at the yamaha dealership near home. lol and they charge people a lot for some simple stuff. so im glad when things can be figured out without my sled leaving the garage. lol
Hey with a great site like this there ain't no problem that can't be solved..LOLSno_Racer_Xtreme said:i thought i was goin to have to take my sled to a mechanic at the yamaha dealership near home. lol and they charge people a lot for some simple stuff. so im glad when things can be figured out without my sled leaving the garage. lol
you only need (1) 2.5mm allen wrench and lay it in sideways to check your gap between powervalave housing sections.
i used 2 one on each side very accurate no guessing on if it's on anmrviper700 said:you only need (1) 2.5mm allen wrench and lay it in sideways to check your gap between powervalave housing sections.
angle,but whatever he wants to do.
Sno_Racer_Xtreme
just double checking, but the 2.5 gap is the gap of the valve off the piston right? i just want to make sure all my knowledge is right for tomarrow morning.
It's the gap between powervalave housings(the housings are two pieces)Sno_Racer_Xtreme said:just double checking, but the 2.5 gap is the gap of the valve off the piston right? i just want to make sure all my knowledge is right for tomarrow morning.
Sno_Racer_Xtreme
ok now im lost again... where is the 2.5 gap suposed be? i thought it was between the valve and the piston. Can you give a good explanation on where the gap is??daman said:It's the gap between powervalave housings(the housings are two pieces)
Measure in the two halfs;
Sno_Racer_Xtreme
if there is a 2.5 mm gap in there though everything will leak out, i dont see how there is suposed to be a space in between there. I am really lost now.
You do your measuring there and if that gap is out of spec. youSno_Racer_Xtreme said:if there is a 2.5 mm gap in there though everything will leak out, i dont see how there is suposed to be a space in between there. I am really lost now.
adjust the cable at the servo..then retighten them two bolts..
Sno_Racer_Xtreme
as far as i know i have just figured everything out. i took it for a little test run around my field and it has unreal power compared to what i rode for about 100 miles (two broken cables). And so far the light hasnt been coming on at all.
Good to hear,,so you figured out how to measure now huh??Sno_Racer_Xtreme said:as far as i know i have just figured everything out. i took it for a little test run around my field and it has unreal power compared to what i rode for about 100 miles (two broken cables). And so far the light hasnt been coming on at all.
Sno_Racer_Xtreme
yeah i did figure out the measureing thing. I was asking to many questions, i just needed to get out there and see it all happen for myself instead of just looking at pics, lol.
thanks
thanks
....Sno_Racer_Xtreme said:yeah i did figure out the measureing thing. I was asking to many questions, i just needed to get out there and see it all happen for myself instead of just looking at pics, lol.
thanks
