Sheermadness03
Gone Blue said:Sheer,
Were can I find out more info on the Bender oil pump set up now that Bender is under new ownership? I am righting this year off and I am not racing to put my motor back together. Since I have my sled apart, I am looking for other mods that make sense. A rear cooler for starters. Thanks, G.B.
I am not sure about Bender's status today, I have heard they are gone, no more,
03viperguy
they are under new management..
http://www.benderracing.com/
Sheermadness03
03viperguy said:they are under new management..
Thanks for the info, looking forward to seeing the "new" catalog.
03viperguy
no problem
hopefully they get it out soon!
viperking
well i got her all torn down and a crank bearing is what it was
Any other problems you can see??viperking said:well i got her all torn down and a crank bearing is what it was
viperking
nope everything else throughout the whole motor was great just a siezed up bearing in the crank. cbperformance is going to fix it for $175
Hell that ain't to bad then,glad the cyl's are ok, you gota ship it out then??viperking said:nope everything else throughout the whole motor was great just a siezed up bearing in the crank. cbperformance is going to fix it for $175
03viperguy
pretty decent price for sure! back on the trail before ya know it
Logan,
Glad to hear it was not more damage to your motor. What all does CB do for $175? Are they just replacing the one bearing, or will they check the rest of the crank out and the rods? Thanks, Brett
viperking
i guess he is going to replace the one bearing and check the other ones. it will be more if anything else is bad. i called another shop and he wanted $200 to do it and he was going to charge me $75 per bearing so it would be a minimum of $275
viperking
oh and ya daman i have to ship it to them in the morning
Ok thanks,viperking said:oh and ya daman i have to ship it to them in the morning
viperking said:i guess he is going to replace the one bearing and check the other ones. it will be more if anything else is bad. i called another shop and he wanted $200 to do it and he was going to charge me $75 per bearing so it would be a minimum of $275
Thanks for the info. I will have to give them a call when I get my case split to see what bearing failed on my motor. Good luck! Brett
viperking
yup good luck to you to
Good luck to both you guy's, and up your pumps when you get 'em back
together..
together..
viperking
ya i asked the first crankshop i called what they thought about upping the oil on the viper and he said it wasn't a bad idea to up the oil a little bit on the viper.
I always hear how they sip oil,,,, but hey who knows maybe thats partviperking said:ya i asked the first crankshop i called what they thought about upping the oil on the viper and he said it wasn't a bad idea to up the oil a little bit on the viper.
of the problem here, Yamaha wanted to be efficient on oil i think but
they got 'em to lean in my book..
03viperguy
I still say the pumps have nothing to do with it
It may not.....but a little more oil sure won't hurt..03viperguy said:I still say the pumps have nothing to do with it
