Argh. It was a slow day. We were battling a headwind, and the ice is not nearly as good anymore.
The motor is now revving 9250, which is great. It's pulling very hard. I have not changed the helix yet, but it needs a higher starting angle. I have not done anything with gearing yet.
I did a few 1000' passes, then a 1500' pass at 137.8 mph.
I then decided to run a 2000' pass, and hurt the motor at about the 1800 ft mark. I am having a temperature issue on the PTO side. Tons of wash on the pistons.....too much fuel actually, which is right where I want it for testing. Zero detonation on the top of the pistons, but I am getting some detonation elsewhere because I noticed that the wrist pin is spinning at some point, which tells me that it is building heat extremely rapidly at some point. The question is why.
At the 1800-2000' mark something is going on. I can run the motor all day at 1500' with no issues, and it builds about 30 degrees total water temperature in that distance, which is far from excessive. I found a cooling issue in the cylinders that is most certainly hindering the flow, and it is going to help out the flow of coolant much better.
Here's a picture of the possible cooling issue. The base gasket on this cylinder matches the base of the motor, so you can see how small the cooling ports are. Just inside the cylinder, the ports become easily as wide as the base port, so the issue is only where it meets the base, and is about 1/4" deep.
In relation, the second picture is a factory SRX 700 (780 actually) cylinder. You can see the difference is size for the cooling ports.
Just to avoid questions or comments, the rough material you see on the Price cylinder is glass. I just finished glassbeading the outside of the cylinders, and haven't washed them yet.
