valin
Ok. The 10 tooth drivers are in. I cut back to just the two center drivers. The 10 tooth drivers fit in the SRX chassis, but you have to remove the front heat exchanger protectors. There is still more than enough clearance in there for the 1" ice picks that I run. I have to thank Doug Swartz (gmcsrx) for letting me know that the 1" picks will work with the 10 tooth drivers, as long as the track doesn't ratchet.
With the bigger drivers, I am cutting back the gearing to 23/38. This ratio, with the 10 tooth drivers, is geared for 134.5 mph at 1:1, which is close to the 24/36 that I was running previously with the 9 tooth drivers (133.2 mph). I was pulling 12% overdrive with that gearing, which isn't very efficient. The reason I wanted to keep the geared speed the same is to see how the resistance is affected with the larger drivers. After I make a pass with that gearing, I will then throw in 24/37, which will gear the sled to 144.1 mph at 1:1, and 151.3 mph at 5% overdrive. I would like to keep it at 5% max, so we will see how it works out for me.
This weekend I will be playing around with many different setups (provided there are no other issues). After the gearing is figured out, I am going to start to throw more helix at it. It is happy with the 37 finish angle I am running, but i know it will like more. More angle = more acceleration = more speed (to a point of course)
