One of those awesome finds. 132 original miles Phazer II with elec. start and a cover that still looks new. Stored indoors with the skis and track off the ground....started right up.
I'm now looking for plastic skis (what mounts work)?
Also need a skid plate, rail extensions and tunnel extension to make it into a 136" if anyone has some tips that would be great.
We even got 8" of snow yesterday to test it out. Christmas in April!
..SNAKEBIT..
My 8 year old is riding a 92 Phazer II LE with a Bender single can pipe, he thinks I should long track it for him to go out west.
SRXtrafast
What was the last year for the phazerII? 98 or 99
yamahaphazers
98. for your question. thats a nice phazer! i got 2 of them and there awesome machines!
So where do I get a skidplate and rail/tunnel extensions?
Bushman
Hartman shows a 116" to 121" track kit, You may want to give Tom a call about the 136" project www.hartmaninc.com
I see that Yamaha made a 136" Mtn Phazer. Might just order the factory rail ext. and tunnel ext from them if it's still available.
Does anyone know if the Venture had a 136" skid?
..SNAKEBIT..
didnt the Venture with the 2-up seat have a 136??
Vmax540
"Does anyone know if the Venture had a 136" skid?" The 2 up Venture TR had a 136" track with cargo rack and the standard 2 up had a nicer seat, rear handwarmers with a 121" track.
I'm confused. The stock track was/is a 116" right? So was the mountain phazer just a 121" or was it a 136"? So a Venture TR rails would be the ticket then?
thanks, Chuck
thanks, Chuck
I've got a '94(red) just like yours there that my daughter rides,she loves it
nice and light for her...great machines,never leave ya walking..
Vmax540
The original Phazer Chassis 1984-1989 had a 116" track, the 1990 Phazer II's were 121" and the ST's were 136".
MSRXRider
A 96 mountain lite looks like this.
and the extended skid looks like this one on my 90 Phazer 2
You might want to try ebay someone has to be parting one out. I thought I had my 96 sold but the rings were froze up so it needs a top end job. It still ran just made noises.
MSRXRider
Sorry about the big pictures.
Vmax540
ssian
Vmax540
"venture has 136" Wrong...... The Phazer styled chassis on the 1991-96 Standard Venture was 121" ! Yes, the 1997 up Pro-Action Plus chassis Venture had a 136".
OK. Those 136" rail extensions look pretty easy to make so I might just make my own.
What drivers do you use for a 1.25" track? Can I get 8 tooth extroverts to fit?
racerrob6m
Not sure but I wouldnt think that you would need to change the drivers for a 1.250 track.
I put a 1" camo on my wifes 93 Phazer2 last year & there was lots of clearence by the drivers. Hmmmmmmm????????
No heat exchangers to worry about so I would get up in the driver area & measure current clearence's. Just my thoughts here.
Good luck. These Phazers are dependable awesome sleds, have had 6 of them over the last 20+ years & never had a major problem with any of them!!
Just a bit light on HP if your a big guy.
Rob
Rob
smittysnow
nice
About longtracking your Phazer....It makes them sweet boondocking sleds, superlight and turns nice through the trees. The Phazer II ST's had a 136" from the factory, I think actually just factory extentions. If you want something that play's very well in the pow then drop to 7 tooth drivers and throw a 1.5" track under there. The reduced gearing affect of the 7 tooth drivers will spin the heavier track. No chaincase gearing changes necessary. You defintely lose some top end but then again it's a 485 fan, who you gonna line up against. Piping the phazer's are a great first step in performance, I think the Aaen pipes give them a nice snap and work well turning the bigger track. One of the best things also to do is to ditch the ski's and go to plastic ones, no need to pay big bucks for new fancy ones, just find some takeoff's and make it work. I have the cat parabolic skis on mine and turning (especially for a kid) is much easier. You just have to do some trimming to the rubber bumper under the pogo. Hope it helps, sorry for the novel!!
