mtsled
This is pretty basic, but make sure to check the wear bars (carbides) on the bottom of the skis. Had on brake and cock sideways. Talk about drag! Also another minor thing is to check ski toe in adjustment.
jlebrun_05
snomoguy said:Here is a little wider angle so you can see a little clearer. Also if you are running your track lose you can add the little wheel kit to the front. It will hold enough tension on the track as come over the drivers, you won't have trouble with ratcheting. I run about 1 and 1/2" slack in my track and have never ratcheted. Now if I was going to a longer track I would go with anti-ratchet drivers since all that would be apart anyway, but this is a quick and easy fix to ratcheting.
Do you know Borg Petterson with Snofed?
snomoguy, you have a picture of how your rear shock is set. As far as the cam bolt on the front, in the top/bottom of the groove. I got the mpi kit set real loose like yours and all the shocks set soft, as well as the limiters let almost all the way out, and the skis will never get off the ground.
venture700
your viper is doing exactly what my enticer 2 done when I put some home made drop brackets on it. there was way to much pressure pushing down at the rear of the track and the front of my track wasnt putting any pressure down. I would get stuck and spin on the smallest hills with hard pack snow
Sledsquatch
- Sep 29, 2008
- Carleton Place, Ontario
- www.simplifiedaudiovideo.com
Have you also checked your gearing, maybe you need to go up a size or two. I know my sled is a spin monster with the smaller gearing.
TTT for a "must read" IMO for anybody who uses a pro action sled in any snow over 2.5 feet deep!
Thx,
Mike
Thx,
Mike
