quad
Trenches
From what I have read in other forums and experienced myself is that weight transfer is your biggest problem probably from your transfer rods when I modified mine it made a world of difference, mind you it is only a short track. But if you check into the aftermarket for mountain riders a kit is offered to eliminate the coupling action when transfered to the back. You may not want to totally eliminate it but at least modify it to get more tranfer to the back, but don't forget you might do more wheelies. Hope this helps and doesn't cause moe confusion
