RTYsxv said:what do you do on a deal like that? Do you need a different crank, or is there some way to take the crank apart? I was wondering about this before when I rebuilt mine, and also if you would have a bad rod or something do you have to replace the crank?
xsivhp said:Just read thru all the posts on your thread - so is it your opinion that a bad crank bearing caused the meltdown?
thats a question for SRXSPEC.....hello bueler, bueler.fasttoys17 said:yes the bearing barely turns on the crank. the only thing i dont understand how or why the piston melted like that
woofer700 said:and to think the same thing happened to my 79, the piston, crank, bearing.
Hey Srxspec, you should see fasttoys work on his sleds, the guy has 10 thumbs, but give him an Audi, and the thing will be done in no time.
fasttoys17 said:thanks joel. you ever get board let me know if you would like to help put back together lol
here are couple more pics. i plan on polishing the tunnel also
