YAMMIEGOD3:16
CAUSE THEY WERE BIGGER. 3:16 (yammie tony)
77 srx used .40mm
78 ssr used .44mm
77 srx used .40mm
78 ssr used .44mm
dynofun said:Really? Where did you get it? Mine was Randy Johnson's and he did oval it. Got a 3rd or 4th at the World Series or something. Dynotech probably would have only got about 90 out of a '77 on his dyno. SSR's are a lot stronger than a 77. Stock pipes did suck tho.
dynofun said:We put on a set of his pipes (Like Aaens) and bingo! 115.6 HP at 10,200 RPM!
Sorry for the thread ressurection but I'm dealing with recreating the factory setup on a set of VM44 power jet carbs for an SSR right now. (actually still looking for a set of inlet bells if anyone knows of a pair)RICKYAMAHA said:What I mean is why is the left one has a main jet of 440 and the right one 240 ??Also the power jet on the lef is # 130 and the right is # 165 ??
Always on the VM 44 (8H![]()
Really? If DTR ever did test publish the SSR numbers in any of their newsletters, I've never seen it!toydoc said:Last number I know of was 98hp at Dynotech
Thanks RJHRJH said:The real factory SSR that I came back to race one weekend when Roy W. left…had:
A 55 mm prototype Mikuni with a butterfly and an emulsion tube.It needed some handling stuff fixed and the clutches worked but could have seen made much better.
(Never made production)
The steering arm was located under the belly pan..
Every piece had been made from thinner..higher quality aluminum..
Offset gas tnak like our older sleds
Clutches were OEM
The thing made more HP than I have ever experienced..
It just tried to rip your hands off the bars..
They had a 340 in the SSR chassis as well so Roy could race more classes..
We had the stocker as well..no where even close to the mod..no where close
Ummm I'm thinking you might have meant something else.bluemonster1 said:all I remember is when my cousin had the 78 SSR and I had the 78 Exciter..I had 2 HP more then his and he could never ever beat me or take me off the line.He was so pissed because of the 2 HP difference.
I don't think Yam ever used those ports in any race sled. I remember asking Gordy back in the day and he said no. I always thought if they didn't think it was worth while why would anyone else...WopOnTour said:haha Thanks Bob, I know what you mean.
I raced an SSR that I purchased in 1979 after the guy that had it before me couldnt make it corner.
On a longer track like Waldhiem or BJ it FLEW though! But then you ended up scrubbing off almost all the gains coming into the corner. Frustrating!
I redid the front end completely, as the thing cornered like a leafer and had way too much bump steer. I yanked then chopped the trailing arms and altered the caster, cut and repositioned the upper shock mount (higher so it lowered the the front of the sled ~1.5") better gas shocks with softer springs and more adjustment, added spacer type rod-ends to better level the rods, replaced the sway bar with a stiffer one with longer link arms AND THEN went to town on the rear skid! LOL
I eventually got it to "get around" as good as the competition and did pretty well with it for a couple years.
But I always wondered what the factory SSR sleds (like Larry O's which I had seen a lot of because I'm out West) had for pistons and porting as he would top end with the Rotax no problem. Maybe not quite as much grunt coming out of the corner but by 1/2 the straight he could reel them in again. (then flog through the corner only to do it all again, obviously hoping for a bad mistake or even a wreck in front of him)
But now I don't recall ever seeing this twin ported piston configuration in anything, so just wondering if that was possibly the secret sauce I had missed out on all those years ago. I've just recently purchased another 78 SRX "basket case" that I want to restore to a trackable state. So I'm willing to get some pistons milled to match up to those small transfer ports as shown below. I just dont know if it would be a waste of time and $$.
So I was just wondering if you might have stuck your head in there and seen something.
Anyone else know of it's origins? Did I miss the boat??
Thanks again Bob for sharing your great memories of those days. (as "cryptic" as they can be LOL) You're the best.
Regards
WopOnTour
Well I've never seen additional ports added to 8F2 or 8H0 cylinders such as these. I presume they have some sort if matching piston ports as well?. Any idea of the results?? (of course only the dyno would tell)dynofun said:I don't think Yam ever used those ports in any race sled. I remember asking Gordy back in the day and he said no. I always thought if they didn't think it was worth while why would anyone else...
Bob, from one old man to another- do yourself a favor and get get back into sled racing. It's obvious the passion and the knowledge is still there. As a team owner or even as a crew chief or pit-man you'll have a blast and can pass some of that knowledge down. While the sleds have changed going around in a circle hasnt. Our team is based out in Western Canada but we've teamed up with a couple of 20-something drivers out in Minnesota for the next few seasons plan to campaign a couple of F500 sleds and work our way up to Pro Champ. Sp FAr We're Lovin it!RJH said:Wow..I like all that work..you did
Same with the 77..they let me drive one of those a few times..
