YAMMIEGOD3:16
Another Thing I Did Was Made Him Install Airbox Back On This Sled. Had K&n Which I Personally Dislike On A Yamaha. 3:16
Dont 8AB weights work good in these sleds for quick drags?
8ab,s & 8ca,s & 8bu-00,s are the same profile. They just weigh differently
YAMMIEGOD3:16
MIKE, I AM BACK TO 8BU ,s IN MY 2000 SRX FOR GRASS. LOVE THEM. I WILL RUN H/C SET-UP ON ICE THIS WINTER THOUGH. 3:16 (yammie tony)
YAMMIEGOD3:16
8BU WERE VMAX 800 WEIGHTS. 8CA WERE VMAX 600. 8AB WERE 95 VMAX 500 AND VMAX SX 600. 3:16 (yammie tony)
I allways had way better luck running hc,s in a SRX with a helix closer to a 52/44ish!
Wow....2 stroke memories coming back!!!!
jabber800
I had a set of 2 stage clickers in our piped 700 Sx last season on the grass. After much testing they ran very well.. We also tried the 8ca set up but never got it working as good as the clickers.. Tony you been running much this year?? We haven't seen the grass yet!! Work and home have been very busy, add in the 600 SRX improver I'm building for the NBSSR radar runs this winter and something has to get cut back..
bufalobob
below is a copy of my dyno sheet posted on dynotech's web site. this is from march of this year. peak torque is @ 8400 & peak h.p. @ 8800. this is a pump gas motor. tony, these are the same pipes you are using. if i run them @ 9000 rpm i loose 6 h.p.. jim @ dynotech will tell you not to clutch a motor to torque but clutch it to h.p..
bob
This 800cc big bore kit has cast pistons, iron sleeves, and very quiet DynoPort triple pipes developed by Tim Bender and Rich Daly. Stock 33mm carbs are used here.
SXR with Bender 800 big bore and DynoPort pipes (this was 110 HP stock)
EngSpd STPTrq STPPwr BSFC B Fuel B AirTmp BaroP
RPM Clb-ft CHp lb/hph lb/hr degF in/Hg
6900 78.3 102.8 0.757 78.5 40 29.70
7000 79.2 105.5 0.747 79.4 40 29.70
7100 78.9 106.6 0.767 82.4 40 29.70
7200 79.2 108.5 0.773 84.6 40 29.70
7300 81.4 113.2 0.764 87.3 39 29.70
7400 81.6 115.0 0.776 90.1 39 29.70
7500 81.6 116.6 0.766 90.3 38 29.70
7600 83.3 120.6 0.748 91.1 38 29.70
7700 85.7 125.7 0.754 95.7 38 29.70
7800 86.1 127.9 0.736 95.0 39 29.70
7900 87.5 131.6 0.724 96.1 39 29.70
8000 89.7 136.6 0.705 97.2 39 29.70
8100 90.7 139.8 0.706 99.9 37 29.70
8200 93.3 145.7 0.687 101.3 37 29.70
8300 93.3 147.5 0.679 101.3 37 29.70
8400 94.5 151.1 0.672 102.8 36 29.71
8500 94.5 152.9 0.674 104.4 36 29.71
8600 93.7 153.4 0.673 104.3 38 29.71
8700 93.1 154.2 0.668 104.1 38 29.71
8800 92.9 155.7 0.659 103.5 39 29.71
8900 90.5 153.4 0.662 102.4 40 29.71
9000 87.3 149.6 0.691 104.3 39 29.70
bob
YAMMIEGOD3:16
BOB THANK YOU FOR THAT. SO I HAVE THAT SX 200 HIGH. VERY , VERY HELPFUL. 3:16 (yammie tony)
DAN, HOW ARE YA BUD. BEEN OUT ONCE WITH VMAX 4, RAN GREAT, LAYED THE OLD BODY SLAM ON MY SRX, BUT NOT MUCH TESTING. FIRST TIME OUT RAN CRAPPY. GOT WILD HAIR TO TRY 8BU SET-UP AGAIN. I LOVE H/C SET-UP THOUGH, BRUTAL ON ICE. MAN, I GOT TO TELL YA A SRX 600 INPROVER, THATS AWSOME. 3:16 (yammie tony)
jmp2204
bold on Jim ...for a 500' drag race?bufalobob said:below is a copy of my dyno sheet posted on dynotech's web site. this is from march of this year. peak torque is @ 8400 & peak h.p. @ 8800. this is a pump gas motor. tony, these are the same pipes you are using. if i run them @ 9000 rpm i loose 6 h.p.. jim @ dynotech will tell you not to clutch a motor to torque but clutch it to h.p..
bob
Those specs are on a big bore motor. I will argue to the death that those pipes on a 700 cc motor need to run lower rpm,s. I tested them personally on 4 piped sleds that I owned for 6 years & they need to be lower. You can not compare rpm,s on a ported out big bore to a stock cc motor. My bender piped 700,s were tons faster at 8200ish holeshot climbing to 8600 max!!!
This was not just 1 sled but 4 of em I personally owned & drag raced every weekend!!!
bufalobob
500' 8600 rpm. trail, lake & long drag races 8800 rpm. my test was a warm motor & pipes. did not hook up to dyno cooling system. i have tunnel heat exchangers added into the cooling system. even on long lake pulls my heat exchangers are just warm.
pipes, heat & compression determine peak rpm. if i had high comp. the peak would be around 8600. the bore & trail porting did not affect the peak rpm. the reason your sled was quicker @ low rpm was because the pipes were not hot. you were making more h.p. @ low rpm's. as the pipes got warmer @ the end of 500' they were hotter & the power band moved up.
bob
bob
bufalobob
pops:
just ran accross an old dyno sheet from max performance. power inc. pipes on stock motor - 137.1 h.p. @ 8400 rpm. will scan & post complete sheet later.
bob
bob
YAMMIEGOD3:16
BOB, MIKE etc. I ASSUME THESE PIPES WERE 9000. I WILL SAY THIS. WE TAR RACED THIS SLED. WE MADE GREAT INPROVEMENT IN THE 1/8. I THINK OUR BEST WAS 6.76 @ 98 mph. I BELIEVE WITH A FAIR 60 FT OF AROUND A 1.5. NOW THIS IS WITH OLD 121 AND STOCK SKID. SLED SEEMED TO NOSE DIVE IN THE 1/4. NOW AGAIN I KNOW WHAT IT REALLY NEEDS. MY ONLY QUESTION TO MIKE. DID,NT THE STOCK SINGLE PIPE ON THE 700 SX RUN THAT RPM. HARD TO BELIEVE THESE BENDER TRIPLES RUN AT STOCK RPM ON A PORTED MOTOR TOO BOOT. AGAIN GUYS NO DOUBT HERE. I WENT TO THE CATALOGS TO FIND INFO ON THESE PIPES. 3:16 (yammie tony)
Bender & power inc end dump run at stock rpm.
Power inc centre dumps run at 79-8100 rpm
I personally owned & tested on my own personnal sleds
Power inc end dumps
Benders
Simon cpr(earlier hauck) pipes
Power inc end dumps
Benders
jmp2204
is that not unusual? porting(raising exhaust port) generally does raise peak hp rpm .no?bufalobob said:500' 8600 rpm. trail, lake & long drag races 8800 rpm. my test was a warm motor & pipes. did not hook up to dyno cooling system. i have tunnel heat exchangers added into the cooling system. even on long lake pulls my heat exchangers are just warm.
bob
Tested em 10 back to back runs.....lower rpm,s were allways 100% of the time with out fail the quickest ET in 1000' or less. This was tested against other sleds week in & week out & I did check against running higher rpm,s. all 4 of my Bender piped sleds(2 were ported) behaved in the exact same way!!!
YAMMIEGOD3:16
MIKE I AM GONNA DO A FULL BLOW,IN TEST SESSION SATURDAY WITH MY SRX ON CLAY, CHISELS, SUSPENSION SLAMED , COOL DOWN , etc THE WAY THE SO CALLED PRO,s HERE DO IT. HERE ARE MY PLAYERS.
21-40 GEARING
8BU-00 WEIGHTS
5100 ENGAG
51-43 DALTON CAM WITH GREEN SPRING /80 WRAP
WHITE MAXXIMUM SPRING
VS
40-10Y NOTCHED FOR 5000
RED SPRING
ABOUT 61. 25 GRAMS
51-37 CAM. @ 80 DEGREE (green)
THAT HEEL CLICKER SET-UP WAS TERROR THIS PAST WINTER, BUT RIGHT NOW IT SEEMS FASTER ON GRASS WITH 8BU. WE WILL SEE. THIS SLED IS SETUP. NO EXCUSES NOW. 3:16 (yammie tony)
21-40 GEARING
8BU-00 WEIGHTS
5100 ENGAG
VS
RED SPRING
ABOUT 61. 25 GRAMS
Tony
Run the 51/43 dalton with the hc,s & slightly lighten up the tip. It will work better.
I don,t like that low finish angle on the 51/37 for grass. Your better off running the steeper finish in anything under 1000'
jabber800
Turk how did you find the Simons pipes to compare with the Bender for drags and lake running.. We ran the CPR's and had decent results but I have a friend looking for a trail/lake set up for his SX. He has access to a set of Bender's and CPR's at this time but I haven't run the Benders so I can't recommend one set over the other.. What would your choice be after running both?
