So what you're going to do is..........
1. Bring the sled into a warm working area
2. Pull cover off the Power valve servo motor
3. Start the sled
4. (a) Turn the idle screw out, so the idle goes below 900RPM
4. (b) Watch the servo motor and make sure it turns then immediately hit the kill switch
5. Mark where it sits now
6. Loosen all the Allen headed screws (6 In each)
7. Take out (4) Allen headed screws in each PV housing
8. Slide one valve out ONE at a time, they should slide right out if maintained Properly
9. Take out remaining (2) screws to separate housings to unveil cable/PV ends
10. Check end of PV for wear/Pull through
11. Put it all back together as it came apart (If everything checks out good)
IF YOU HAVE PULL THROUGHS GET THE SS BOLT MOD DONE, OR GET NEW PV'S AND CABLES. KEEPING THEM CLEAN AND ADJUSTED PROPERLY WILL LOWER THE CHANCE OF THIS HAPPENING AGAIN!!!!
After this is all done and they're fine....... Adjust them........
1. Loosen adjusters at the Servo motor completely.
2. Get (2) 2.5 or 3mm Allen wrench (Key)
3. Loosen 4 allen headed screws
4. Place both allen wrenches between the PV housing and the CYL
5. Tighten adjust at Servo motor until the Housing tighten up on the Allen Wrenches
6. Repeat for other two Cyls
When the power valves aren't functioning there is a noticeable loss in power and enjoyment!
3. Start the sled
Ride.Race.Live
Ok im back sled was still warmis.. started no choke so didnt take too long..
Ride.Race.Live
Jebus!... never did any work on the sled yet.. this is going to be interesting!...
how long will this take me about.. im not familiare with my sled nor do i kno much about it... I dont wana be up all night trying to do this.. would i b better of starting this tomorrow right after work?
Ride.Race.Live said:Jebus!... never did any work on the sled yet.. this is going to be interesting!...
Where are you In Ontario??
If you don't have a clue I would advise letting someone else do it. Although it's not overly difficult at all!
It took me about 15 Mins to take apart. 24 hours for my PV to sit in a cup of cleaner. 30 mins to assemble and Adjust. CLEAN THEM WHEN THEY'RE OUT!!! EVEN IF THEY "LOOK" CLEAN!!!!
Ride.Race.Live
I live like 1hour east of ottawa.. Curran but ppl never hear of my village... if uve heard of rockland or bourget or hawksbery im in batween there
kk ill wait till my dad is back around n well both hit that.. dont wana mess things yuo
Ride.Race.Live
My pv valves where cleaned when i bought the sled wich was like a little more than a month ago.. n i just started driving the sled.. i put like 4-600 clicks on it?
Ride.Race.Live said:I live like 1hour east of ottawa.. Curran but ppl never hear of my village... if uve heard of rockland or bourget or hawksbery im in batween there
Way to far for me to help you out, LOL!
I would leave it for tomorrow after work. Leave yourself a good 2-3 hours, Because you'll clean them at the same time!
Ride.Race.Live
haha yea.. wish u where closer.. prob would of gotten her dialed in pretty good i could imagine... with the help of some good ol prime canadian beer too..lol
ok ill leave her till tomorrow..hopefully ill have my dad around to help out..
hmm wonder if theres anyone close that would b able to help...
Ride.Race.Live said:haha yea.. wish u where closer.. prob would of gotten her dialed in pretty good i could imagine... with the help of some good ol prime canadian beer too..lol
What are you running for a helix? Spring?
What weights in the comet? spring?
Ride.Race.Live
n thats where the bad part starts..
Got no clue what helix im runing.. its a bender n the helix has no numbers on it...
primary spring is purple and secondary black.. dont kno the primary weights.. they where lightend on the comet to increase the rev...
LOL, Oh ok. Well then I can't help there. What model Comet?
Ride.Race.Live
its the 108exp
Ok you should have the AC arm. Did it have "AC" On it?
Ride.Race.Live
where would it say AC?... my mech installed it for me.. so i dont got any papers or nothin on it... would it say it on the clutch itself?
No on the side of the arm itself. No big deal I was just curious. i swear by the Yamaha Clutch.
Ride.Race.Live
Yea.. i would of too if i knew more about this stuff... but i made a mistake about gettin the coment but kinda late now.. so im gona work with what i got for now..
Ride.Race.Live
Im still lost on how the engine would be still running great with messed up pvs.. = /
The engine will run, But won't have full potential on top end. Many have no Idea they PV's are pulled through, or out of adjustment.
Ride.Race.Live
yea... kinda really random! since the only that that changed was the top end n not the rpms as well...
srxbully
ok first how fast is 160 & 140 in mph??
& the sled should idle fine if the valves are pulled through?? is that when its running good??(idleing)..& then i would ditch the comet..find a used primary with 8dn-20's(long cover). most of us have learned from our mistakes so get out there and at least take the valves out of the clyinders & see if there pulled through?? it will help you sleep tonight.i know it will.& then when you go to clean & adjust them tomarrow take the pipes off & adjust.
