What I have found:
When starting SXs, SRXs, + Vipers, after they have sat for a long time, make sure you have well over 1/2 tank of fuel[ie:FULL].
If you look at the routing of the fuel line from the tank to the pump it has a loop that rises to about 1/2 the height of the tank before heading back down to the fuel pump, because of this the fuel can only get to the pump by its own suction when the fuel level is below the height of the line.
When the fuel level is above the height of the line the fuel will gravity feed to the pump so it will need far fewer pulls as it does not have to "suck" the fuel from the tank.
I have removed the fuel tank fuel line fitting on my SXs + SRXs and turned it upside down with a short fuel line to the pump so I no longer have this issue.[no more loop]
Works for me!
Works for me!
