valin
I just picked up another project.......1997 Banshee. It's rough.........it was cheap.....and it'll rock when I'm done.
The motor is going to be a 4mm stroker, ported cylinders, with a coolhead, on 33mm carbs. It is going to be a 91 octane pump gas motor. It should be fun.
The frame, swingarm, a-arms (if I keep the stock ones), cases and cylinders are going to be gloss black. The rear carrier, and front and rear hubs will be bright red. Plastics will be black, black nerfs, basically everything will be black. Pipes and clutch cover will be chrome. Water pump cover, stator cover, intake manifolds, and coolhead will be billet. Front bumper will be polished aluminum.
All of the black and red will be powdercoated. I am going to get set up and this will be my first powder coating project, so hopefully it turns out decent.
On with the pictures. Today I stripped everything down to the frame. The frame was originally silver, but painted over with black, which was all chipping and peeling. Isn't she a beauty? LOL....
I just placed the plastics on the bike. They are not actually mounted, which is why they look all warped.
Last pic......had to capture the 1136 in there a bit
