delemi
I bought this sled 2 1/2 years ago.
2001 SRX 700
When I bought this sled it ran (well enough for me to buy it) until it became warm and then it would start missing on the right and center cylinders (facing the front of the sled). I did a compression test and it had little compression. So i tore the top end down and sent the jugs to a machine shop where they discovered both cylinders had a tapper in them. The machine shop was unable to bore them out because of the nikasil plating. So I sent the Wisco rebuild kit and the jugs off to US chrome to be bored and re-plated, a few weeks later everything came back matched and looking like a million dollars.
Do to work I sent the sled and parts down to White Bear lakes Tousley Yamaha and had the top end reassembled. The season was about over but I did manage to zip up and down the alley behind my house a few dozen times.
So the sled sat and was serviced for the off season and was taken to Michigan for storage. I went to use it last year and it wouldn't start. I had no spark! After doing some research I determined it to be the stator and sent it to RM Stator where they replaced the magnetic pickup and told me it tested out at specs.
Today I put the Stator and pick up on. And while I was in there I rewound the recoil spring so it would suck my rope in all the way (brave I know). 30 minutes later I have a smooth pulling recoil and a bit of piece of mind. I pull it over a few times and no start. Made sure the key was on, safety switch was up and tried again. Same result.
Checked for spark, no spark.
Disabled the carb safety switch.
I sprayed starting fluid in the carbs and noticed the right cylinder fires I ever 5th or 6th pull but nothing else.
I notice my headlight is not trying to light up during pulls.
I plan to check the stator in the morning.
Then the DC regulator and condenser
I need peoples ideas and help to solve this. I have stuck so much money into this and never had the opportunity to take this machine out on the trails.
Any and all help will be appreciated.
2001 SRX 700
