YAMMIEGOD3:16
I WANT TO SEE IF MY INFO IS CORRECT, ANYBODY HAVE SPEC ON THIS SPRING. 3:16 (yammie tony)
staggs65
mcb performance lists it as 230-350
I do it is STIFFFFFFFFF Sorry couldn't resist.
the one I have is at 230-360 rate but I going to buy a new one sometime this winter so I can get all I can get and go as fast as I can go
your not goona go fast with heel clicker
harness racer
modsrx said:your not goona go fast with heel clicker
if your talking ET. THAN YES WELL SET UP IT WILL GO FAST
if you want top lake speed than MOD is correct...
i try many helix and weight in different place in heel clicker and didnt get good top end ....
Ok........I'd like to accellerate faster and get there faster......!!!!!!modsrx said:your not goona go fast with heel clicker
Better MOD lol
mopar1rules
YAMMIEGOD3:16 said:I WANT TO SEE IF MY INFO IS CORRECT, ANYBODY HAVE SPEC ON THIS SPRING. 3:16 (yammie tony)
tony, the info i have is 230/360 and 1.79kg rate. is this what you have? i have seen it also written down as a 230/350 spring. i was going to have my buddy measure the spring out on a valve spring tester, but the spring is too long to fit on the tester.
YAMMIEGOD3:16
JOSH AND OTHERS THANK YOU !!!. THATS THE SPEC I SHOW. HOW ABOUT A H/C WHITE SPRING. ANY INFO ON THIS. 3:16 (yammie tony)
mopar1rules
going off of memory, i think the white is a 170/300?? if so, then the rate is also 1.79kg...same rate as HC red spring.
bufalobob
red 230/360
gray 230/330
white 170/300
black 140/400
heelclickers are a excellent speed run weight. in back to back testing @ nbssr ( 2000' ) i found only 1/10th of a mph difference between 8bu00 & HC's on my IS700 srx. this was a full bodied sled - 755# w/ driver!
got almost the same results when i tested both on my 835 trail sled.
bob
gray 230/330
white 170/300
black 140/400
bob
jabber800
Bob where you been hiding lately?? Do you have that SRX project together for this winters NBSSR runs? Quick question on your set up with the heel clicker weights.. Where you running there springs?? Did you try anything else for springs? I used a set of clickers with OEM yamaha springs and had pretty good results for top end speeds..
bufalobob
dan:
haven't even started the project. waiting on the sponsor to do the motor!
i always used the red hc springs. did you find a difference?
bob
bob
jabber800 said:Bob where you been hiding lately?? Do you have that SRX project together for this winters NBSSR runs? Quick question on your set up with the heel clicker weights.. Where you running there springs?? Did you try anything else for springs? I used a set of clickers with OEM yamaha springs and had pretty good results for top end speeds..
What springs were you using for top speeds with Heelclickers
mopar1rules
i played a little w/heel clickers and the stock y/w/y spring w/decent results. i lost access to that set of heel clickers, before i could try any other springs.
Sorry for stealing your post Tony but the heelclickers you (Mopar1rules) were using were there any notches or cut to these weights or just stock HC weights just looking for every little bit info on heelclickersmopar1rules said:i played a little w/heel clickers and the stock y/w/y spring w/decent results. i lost access to that set of heel clickers, before i could try any other springs.
mopar1rules
tony, sorry for hi-jacking too....
.....they were unmodded plan old 40-10BY heel clickers.
YAMMIEGOD3:16
GUYS , NO PROBLEM ON THE HI-JACK STUFF, KEEP THE GOOD INFO COMING. !! I DID NOTCH MY HEEL CLICKERS FOR A HIGHER ENAGEMENT WITH THE RED SPRING FOR GRASS AND ICE. THEY ARE A GREAT DRAG RACE WEIGHT , BUT I AM NOT GONNA SAY THEY BLOW 8BU WEIGHTS AWAY LIKE OTHERS HAVE SAID HERE. GUYS, HERE IS MY NEW SET-UP IN MY 2002 SRX FOR LONG HAUL BLAZEING.
8BU-10
AROUND 55 GRAMS.
23/38 GEARING
47-41 CAM @ 80
MIGHT THROW A BENDER CAN ON FOR ALITTLE NOISE, BUT STOCK MUFFLER WHEN I WANT TO RUN. KEEP IN MIND THIS IS MY LAKE RUNNER. 3:16 (yammie tony)
8BU-10
AROUND 55 GRAMS.
23/38 GEARING
47-41 CAM @ 80
jabber800
Tony that set up is close to what we ran in our stock 2000 srx for 2000 ft radar runs. 8BU10's fully loaded with a couple grams extra in the outside hole. WWW spring, pink secondary wrapped to around 70 degrees, helix finish around 40 degrees (i varied this from 38 to 41) This set up changed from day to day depending on ice conditions, winds, air temp and pressure. We where always competive in our class.. Won a whole lot more ofter than we lost.. I think we where 9 first and a second last year in NBSSR trail stock..
Tested heel clickers with YWY and GWG springs, had to notch weights and cut spider and split collars. Worked well on a modded SX.. Haven't tried it on my SRX's yet but think they could work for the stocker aswell..
