"who knows what this is for"
amatosrx
VIP Life Member
byron center mi
who has seen or used this special tool for yamaha sleds. just curious i use it all the time great tool.
Primary spring compressor to help change clutch weights??
Secondary spring compressor to help install and remove helix??
Nicko said:
puller for the driveshaft bearing....
correct this puller pulls the shaft out of the chain case so you can get the track off the cogs with out removing the chaincase and brakes saves alot of hassle and about 45 minutes of time .
