SX_SLAYER
piston pin puller???? lol idk, random guess
A convenient tool for placing extra or unwanted washers...........
T.S.U.Filmz
hahaha i know what it is i wont give it away but i will say that SX slayer is right about it being a puller
somebody has to know. this tool is a lifesaver saves alot of hassle.
maxwell
Looks like it could be for a clutch compression tool.
no not for clutch. this is a custom made tool.maxwell said:Looks like it could be for a clutch compression tool.
Hifax/slide puller
nope.Nicko said:Hifax/slide puller
So, why such a secret? Just spill the beans already. This is getting old!
I am going to say it is for pulling the power valves . If it is I'll bet it sure is a lifesaver .
SS
SS
stud puller then...
Primary spring compressor to help change clutch weights??
Secondary spring compressor to help install and remove helix??
T.S.U.Filmz
lol think a little lower then the clutch like the track area
puller for the driveshaft bearing....
correct this puller pulls the shaft out of the chain case so you can get the track off the cogs with out removing the chaincase and brakes saves alot of hassle and about 45 minutes of time .Nicko said:puller for the driveshaft bearing....
What do I get...? A tap in the back maybe....LOL
Nice custom tool...
Nick
Nice custom tool...
Nick
sleddineinar
Now that's great idea! Not the tap in the back, but the tool. Very cool!
OnDaTrail
Why is there a slot accross the top of it?
do not know it was given to me by a yamaha tech.OnDaTrail said:Why is there a slot accross the top of it?
