no not for clutch. this is a custom made tool.maxwell said:Looks like it could be for a clutch compression tool.
nope.Nicko said:Hifax/slide puller
correct this puller pulls the shaft out of the chain case so you can get the track off the cogs with out removing the chaincase and brakes saves alot of hassle and about 45 minutes of time .Nicko said:puller for the driveshaft bearing....
do not know it was given to me by a yamaha tech.OnDaTrail said:Why is there a slot accross the top of it?
