concept carbon vs modsrx
Only problem I see here is you both dont have the same port specs, modsrx is a little more like "lake race" and concepts is a st/2 viper with a little extra twist...lol. I cant tell anymore then that.
Every engine I do is custom so.... no 2 are the same, hence its hard to compare engine numbers when doing this. Engine is set up to the" users needs", not a "mass produced" same engine fits grandma as 19yr old male....
I tossed the the viper cdi along time ago and run an 01 srx one. I might do my last run with 50%avgas to see if there is anygain its free why not
humm I thought modsrx was trail ported.......sneaky. lol
Dyno will make clutching alot easyier, soon I will not wha tmy target rmp is. viper is 8600 srx 8400 srx piped viper with a shorter header???
If I ever get my act together and quit keyboard racing I could turn it into ModSRX vs Concept Carbon vs WNYViper... then things would be stacked against the SRX, lol...
modsrx said:
ill keep my cdi i doesnt wanna do a burn down :o| but i can let it try if he want too
I just noticed your SRX is a 1998...CDI would'nt work in the Viper anyway...also looks like Carbon is already using a SRX CDI.
srx is a 98 but the ignition on it its a 2001 ........ ;)!
yes yes its a trail ported sled :nos: ...i come mr viper reply here lollllllllllllllll...its gonna be fun this winter
This is getting more interesting by the minute! Can't wait for the outcome! I hope you post all the numbers. I am very interested in the shorter header pipes on the the Viper to see if opens up some untapped HP by raising the RPM a bit.
ill show u the one i got if it pull more hp than stock :o|
Il contact them tommorrow to see if we can make an apointment in a couple weeks. Dont have all my parts yet.
same here damm boots :o| ... does i need to bring a clutch or something ?? never did a dyno on a sled
parts came to the door taday, mrviper did an amazing job. Its almost all together just need a dowel pin for heads cant find it in my junk.
