WNYViper said:Concepts Viper... (I'll call MrViper up right now just to make sure, lol!)
ported viper and ported srx (where is concept carbon lolll)05mtnvipermod said:post up the specs of each
WNYViper said:Concept Carbon has SRX triple pipes... JAY!! WHERE ARE YOU??!?! lol
modsrx said:must be scared somewhere loll..just kidding about the subject..hope it will pull good number
WNYViper said:Where are you guys going to dyno them?
Concept Carbon said:1995vmax500le friend has a dyno in armprior.
I wonder who will pull harder. I guess it will come down to whos got the better porting. Only real difference is the heads and manifold and powervalves. I might have a little trick or 2 up my sleave...................................................................................................................................................................................................................................................................................................................cough cough ........avgas....100LL.
I may bring some just for fun....
jabber800 said:The ignition system could come into play here aswell.. All thing equal cylinder porting pipes cases and fuel system, the hotter timing on the viper ignition could help it pull the bigger # on the dyno.. JMO
ill keep my cdi i doesnt wanna do a burn downsideshowBob said:I would be very interested to see the two sleds run on the Dyno then the CDIs swapped between the sleds + run again!
