bender pipe and can question
viperking said:
if i install a bender single pipe and can on a 780 viper will i have to change the jetting at all?
I think any time you change the expansion chamber on a carbed 2-Stroke you'll have to change the jetting aswell, and the clutching too.
If not already, ceramic coat or heat wrap the set-up before you jet and clutch. I lost power with my Bender 4x4 and SLP can at first, then I had my manifold, pipe, and can ceramic coated at Jet-Hot. Got the power back plus a little. Shed a ton of weight off the nose as well. It did require re-jetting, but not enough impact to justify messing with the clutch again.
no, it had a stock pipe and can on it and im just switching to a bender single pipe and can, it's clutched for the stock exhaust
