yep I tried them a few weeks back.Lugged the motor down with the setup..Must have to much weight in the arms.Have 4.5 both holes.Only pulled at 7000 rpm's .My stock weights and helix I am pulling good and quick.Got it up to 95 on the river no problem and running 8500 rpm's.Like it to be a little lower and climb up to 8500,so added 2 washers to tip rivet to make it about 5.4g now.That should work fine.But scratching my head on the 8bu-10's.
Stock weights are running at 53.4 grams and 8bu-10's are running at 55.71 grams.That is only like 2.5 grams heavier.That shouldn't drop rpm's by 1500.I should of started out empty on 8bu,s first and then added as needed.Now since I have 4.5 in both holes,I will drill a hole in the middle of them to drop the weight and see what gives.I am using a Bender 50/40 helix also and red spring at 80..
Other helix's I have are..yamaha 45,47,51/43 and 49/45 Bender and a 54/44 .
