This should not be too difficult. The only tricky part is removing the harness from under the engine. When you pull of this part if the harness, attach a string or wire to it so you'll have it to pull the wiring harness back in place. The rest of the harness is under the cover which surrounds the gas tank. Why do you want to remove it? Are you looking for a short or bare wire??
