Hi guys!
Viper Mountain 5000km on the clocks.
Yesterday my good old yammi let me down, it`s the first time a Yamaha has le me down.
I think I need to tell the whole story so here goes:
Last year I had some minor cooling problems, the cooling light came on a few times at the end of the season and I had to add some more water/glycol. But I only had to add water/glycol one time (last ride).
So when I ordered some parts from Rich due to my pre-season tuneup, I ordered all the gaskets/seals for the waterpump.
Since I have been building a trailer this fall I got delayed with my sled pre-season tuneup, so I decided to skip the waterpump and just have a look after the first startup. I held a mirror down under the waterpump and I could see drops coming out of the weep hole.
So I took the engine out of the sled, replaced all the seals in the waterpump
and put the engine back in.
After having filled it up with water/glycol I used my hands and "compressed" the cooling hoses and I could see that the water level in the expansion tank got lower, so air in the system was replaced with water. I did this alot on all the hoses I could see.
(I couldnt find any bleeding screws, and I read that the Viper ER had one buy my mtn didnt).
So I figured out that I needed to pay attention to the coolant level after I had started it, which I did, and I added coolant until the level was stabilized.
I also put my hands on running board coolers and the rear cooler to make sure they were hot and they were indeed hot.
So I thought I had aired it good enough, or ??
As for the oil pump I opened the bleeding screw before I started the sled, I made sure that oil came out of the screw. I could see that it drippled pretty good.
Then I started the sled and let it idle for a few minutes, I then opened the oilpump bleed screw again just to make sure it was aired properly.
As a part of my pre-season tuneup I bought a heelclicker kit. I used the red spring, 5 grams in tip 3.3 in heel. The engagement rpm was a little high (just below 5000) and "brutal" but I`ve heard that clickers act that way so I didnt care that much about it.
Last weekend we went riding in Sweden, it was about -22 celcius and the trails were freakin hard with very little cooling snow for the slides/engine.
I had new slides and my girlfriend also came along as my passenger.
After riding 500 meters we had to stop cause I was freezing my hands off, before I stopped I heard that the track/slides squeeled. When I then hit the throttle again the track had melted into the slides so the track didnt spin.
I had a friend lift the rear end of the sled and I blipped the throttle so that the track loosened.
We continued riding and it didnt take long before my cooling light came on.
I stopped and put snow on the runningboards.
Continued riding but the cooling light returned and I decided to try to keep out of the trail to get as much cooling snow as possible.
But I did ride with the cooling light on for some time.
I also noticed that the rews were kind of high, does the engagement rpm affect the rpms throughout the hole rpm scale? (I wonder this since my engagement rpm was just under 5000).
So my question is, could the fact that there was little cooling-snow which made the slides hot which again made the track heavy to turn, which again made the engine raise its rpm to keep the track spinning, that in turn made the engine run hotter and because of the lack of cooling snow for the coolers also made the engine run hot?.
Anyway later on the day the trail got softer and I had no problems when we went back to our trailers. We rode about 70km that day.
When we got home I put my sled in the garage to figure out what was wrong with my heated grips. I then noticed that the oil consumption seemed little, I did fill the tank up to the lid before I took my first ride this year, so I thought it had used little oil.
Therefor I aired the pump one more time.
Yesterday we went for a ride back home and the trail was alot softer then it was in Sweden. But due to little snow we had to ride a gnarly trail with low speed, so I did get my cooling light on. I stopped and put snow on the running boards then continued for a 150m and then the rest of the guys decided to stop for a few minutes and then when we continued my cooling light was gone.
We rode up a long hill and in the middle of the hill the sled made a little "boooo burble" but after a split second it was back to normal, and then after 100meters it stopped. I pulled the plugs and found out that the center plug had some aluminium bits on it, so I knew what had happened.
Towed the sled down to the trailer, went home and tore it apart.
Here are some pictures:
Used the oil trick to get the primary off, with a cut down puller.
