ive just about had it with this stupid thing... desperately need help
hey bud I have had same problem, cost 800 bucks to track down problem.
take your primary off and check roller bushings if worn a little it will change shifting properties. 45 bucks to fix problem. might be the problem might not, its a sled after all. hope it works
well theo is partly correct, the fuel pump pumps air into one side of the carb, so i need a new pump/rebuild, i have someone looking for a rebuild kit, if he finds it i might try that, but other than that im done putting money into this, but yesterday it was so bad it couldn't cross a road without me pushing it
Can U find a fuel pump locally? It is a common mikuni pump. Maybe a buddy or someone has one u can borrow? Check local craiglist. If I had one I would help u out. Maybe your local dealer has a new/used one and can help u out. Does not have to be a Yammi dealer very common pump.
i have someone coming out here right now to look at it, so im putting things back together the way there supposed to be so it looks normal... how much do you think a normal price would be, i said 500 OBO
