SWEDE
Good to hear thanks for the input, Journeyman seems to really like them as well.
madzx2
now that there is no more snow i can start to work on my sled. anyone have any hints or tips on removing the belly panels?
madzx2
i measured my squish today
PTO: 0.051
CTR: 0.050
MAG: 0.052
Compression is 120 psi across all three, cold throttle wide open
PTO: 0.051
CTR: 0.050
MAG: 0.052
valin
madzx2 said:i measured my squish today
PTO: 0.051
CTR: 0.050
MAG: 0.052
That's a bit tighter than I like to run on pump gas.......
madzx2
valin said:That's a bit tighter than I like to run on pump gas.......
thats what ive gathered from reading today. i ran pump 92 last year. what octane would you reccomend?
valin
The type of fuel that is required to run is not really dependent on the amount of squish you have........more so for compression ratio. You can get away with running less squish if you are running a narrower squish band, or if the squish band is on a larger angle. Obviously it is staying alive on pump fuel if you've been running it like that, so I'm sure there is no need to worry.
madzx2
madzx2
i picked up a 4 window digitron, 4 billet skidframe wheels, a pair of bender racing steering arms, and a set of vforce 3 reeds at haydays. have pics up soon.
madzx2
Ride.Race.Live
what that didgitron do overall?
madzx2
Ride.Race.Live said:what that didgitron do overall?
rpm, 3 egt's, and water temp. also records and playsback.
madzx2
took the sled out today for the first ride. we got about 20" of snow on saturday. got to do some clutching but overall had a good ride. i tinker with this sled more than actually riding it. but then again i love to tinker and try different set ups.
madzx2
this summer i will be installing a mr viper 780 top end, 136 track with 9" idlers and hopefully fox floats in the front and rear.
tippmannator
look foreword to following that build-up! keep us posted!
madzx2
staggs65
them proactions sure are heavy arent they?
madzx2
My goal its to take at least 10 pounds out of it. I know its probably best to get a different skid but I like messing with stuff.
madzx2
super1c
Super Moderator
What was the fox float off of? Might consider that instead of ohlins for the wifes skid. Thanks chris
madzx2
This float was of a 08 Arctic cat crossfire, its eye to eye is 18.8" its a little longer than the stock shock but it should work ok. I know they make other floats that are closer to stock but I got a good deal on this one.
