Spinner18
blue, why buy an apex? my stock 700 srx walks away from both apex's i ran on the lake...
coop99srx said:my younger brother has a nytro and he kills me in a drag race by at least 2 sled lenghts
coop99srx said:any good suggestions on having the local engine shop make my 700 a 800
I think he got his feelings hurt by everyone right away telling him to remove the Hauck silencer?mopar1rules said:CAUSE YOUR SLED NEEDS SOME TLC!! why are you ignoring peoples questions? i asked you, "what max rpms is your sled turning now"? need to know that, as that is important info. you come on here wanting help, but you won't listen to us on here that know a thing or too. i just don't understand some people.
any 700 srx, shouldn't have any trouble spanking a nytro. they are 120hp (earlier models) and 130hp (newer models). a stock srx is approx 140hp, w/lot longer legs too.
Spinner18 said:you can run a different secondary helix with stock primary. you should have 8dn-20 weights, remove the inner rivets, and install 4.5 gram rivets with stock primary spring, get a micro belmont 52/46 helix, and stock red primary spring wound at 90. at 40* out with stock jetting and shitty snow conditions, i was pulling 105 every pull on GPS, and no doubt it will be faster in colder weather. but even in the warmer weather, i was quicker and pulled away on top end from an 09 apex and 09 dragon 800. this setup works
coop99srx said:you asked earlier about my max rpm i believe its 8500 but not sure
coop99srx said:my sled is actally a 99 but im sure there the same 2000 would be different . I cant say for sure about my rpm's but it does run strong to 8000-8500 its at about 6500-7000 that it just dies off i did notice that my belt is not sitting on top of my secondary not even flush could be my secondary helix?
