sleddineinar
finally the rear suspension...
What do you guys think about this? As far as how it's sitting...
And also a word of advice... If you have the front belly pan panels off and take out the lower bracket that the bumper supports bolt to, make sure you re-attach it to the front belly pan piece before you rivet everything back together. I had to take it all back apart after trying several things to get that bracket to go back in (WHAT A PITA!!!),
it threads through the plastic on the inside and the rest of it is on the side where the radius rods attach...
it threads through the plastic on the inside and the rest of it is on the side where the radius rods attach...Attachments
sleddineinar
mdbauer62
looking good - cool idea to stretch and Viperize a Vmax...anxious to see the final result !
sleddineinar
Houston we have a problem...
I took these so you can see what I'm talking about. Anybody know what I'm doing wrong let me know please. Now that the skid is in, and I sit on it, it moves down, but only until the rear arm hits the back stop. then it stops and nothing moves at all. I've noticed that the rear shocks bottom mount seems like it should pivot up or forward, but it doesn't See how the pivot is sitting? Also when I install to the C to C measurements I got, the limiter straps have a bunch of slack in them. Now earlier I tried mounting the skid to holes in the rear mount that were 1 1/2" forward. I got that measurement from measuring the skid out of the sled just sitting there. Mounted that way the skid didn't move at all. (The reason I did this was because someone that has been helping me said that was what to do.) I'm stumped... please help!!
The sled is going to look great. I really like the use of the Viper seat. What cross over cooler are you going to use? Al
sleddineinar
alswagg said:The sled is going to look great. I really like the use of the Viper seat. What cross over cooler are you going to use? Al
I thought about using the srx cooler, but decided to use the one from the sled and have the tubes turned so that the cooler sits up in the tunnel instead of across the back. I had a welder cut & reweld the tubes. Here are a couple pictures.
sleddineinar
Should have
You should have had the welder cut off the coolant bleeder bung & weld the hole shut....then he could have welded it in the proper place for the hole in the tunnel extension. But you'll still get it bled fine with that hole....just wont be as handy. I'm just mentioning it because those are some fine looking aluminum welds and I'm sure the guy could have done it for you pretty quickly.
Madmatt
Madmatt
sleddineinar
I almost had the welder do that, but for whatever reason I just decided to leave it where it was and put small hole in the back of the extension to make bleeding a little easier. Today the track & skid are installed and the motor is in place, I just need to hook all the hoses and put the exhaust and the chaincase together, before I can fire it up.
sleddineinar
Alrighty now, here are the pipes. everything is done but the carbs, I need to clean and rejet them before I go any further. If I like everything I'll be getting things powdercoated after the season is done.
BTW, the guy told me they are Bender pipes, but they don't look like Benders to me, does anybody have a guess? I took the main jets out of his carbs and they were 145s. His sled was a '97 700sx and he said he bought it when it was a year old and the pipes were already on it.
That curly mag pipe looks like a set of cpr's that we had. Might me hauck too as they were basically the same pipes.
You finally figured out that suspension
That's cool.
That's cool.sleddineinar
Yea, the suspension is pretty stiff though, looks like I'll be looking for some aftermarket shocks on ebay. But I'm eager to hit the snow and see how it runs. Hopefully I'll have sometime before this weekend to take it out and do some testing.
P.S. I checked out the Simmons CPR website and they look just like that. Thanks.
sleddineinar
I fired up the old girl today. Here is the video I took with my phone. The first time I fired it up, it took 3 pulls, it fired on the 2nd pull!! I think it sounds pretty wicked!!
http://www.youtube.com/watch?v=6dWPBYvA59I
PhatboyC
Sounds good!
PhatboyC said:Sounds good!
Good...?
I think it sounds like a raped ape......
Can't wait to hear it in person, maybe even try to smash it into a tree or rock....lolNick
sleddineinar
Thanks for the jets today Nick, I'll get the pilots I ordered tomorrow and have it ready to go for ride this weekend. Not sure if you get ride it though... you have a record, you know... LOL!!! ...Maybe out on the lake where there are no trees.
I thought he found a rock in the middle of the trail when he tore up that viper
Glad you got it all together.
Glad you got it all together.sleddineinar
Yea you're right, I'll have to make sure there aren't any rockpiles out in the lake...
03viperguy
looking great, nice work. I am jealous of you having the place and ability to totally tear it down that way. I have neither lol! and yes, that sounds MEAN
sleddineinar
Thanks. If all goes as planned I'll go for ride this weekend and get a couple pictures posted.
