sleddineinar
finally the rear suspension...
What do you guys think about this? As far as how it's sitting...
And also a word of advice... If you have the front belly pan panels off and take out the lower bracket that the bumper supports bolt to, make sure you re-attach it to the front belly pan piece before you rivet everything back together. I had to take it all back apart after trying several things to get that bracket to go back in (WHAT A PITA!!!),
it threads through the plastic on the inside and the rest of it is on the side where the radius rods attach...
