nosboy said:Mothballs are made from ETHER... Need I explain any further???
ALCOHOLS ABSOLUTELY HATE lubricants like TWO STROKE OIL... The alcohol actually destroys the "oil film" and promotes FRICTION.. STUFF WEARS OUT A LOT FASTER using alcohol as a fuel.. The DRAG racers that use e85 and methanol have to change their oil CONSTANTLY.. They have to DRAIN THEIR FUEL SYSTEMS after every day at the racetrack... Rubbers have EMMOLIENTS (lubricity) that keeps them from drying out and turning into a powdre... ALCOHOL removes these emmolients and DESTROYS rubber ( lubricants too).. SYNTHETICS are a MUST when using ethanol or methanol blended fuels !!!! ( not amsoil either)... We'll talk about BEAN OIL later....killerklown said:I remember a couple years ago one of my know-it-all guys here in town ran HEET in his sled, I don't know for sure how much he put in, but teh sled sure didn't last long.
Thanks Matt !Madmatt said:Nothing is as "volitile" as it used to be......except maybe with the exception of NOSBOY!!!!
Madmatt
Heet in the little YELLOW bottles.. (methanol) Heet in the red bottles is isopropyl alcohol.... No need to waste your money with todays fuel.. If you have WATER in your fuel,, it will FREEZE and turn into chunks of ice and will not harm your sled.. Water turns into a solid at 32 degrese F.Spinner18 said:when your talking about HEET, are you talking about ISO-HEET? My dad's ran that in his stuff for years. About 1/4 bottle to every tank of sled fuel, not adding during the ride for the day, but always when getting home or just before leaving. Never had any engine failures in 30 years...
nosboy said:Good thing MikeSr.. it's about time I can talk to someone who has an education.!!!!
that ain't all true! what about the guy that keeps their sled in a heated garage or when the temp is going above and below freezing .the chunks of ice melt and can then get sucked up and pumped in to the carbs and as you know these carbs have no water traps on them so the water sits there right around the main jet waiting for the temp to drop and refreezes then the next time you go for a ride the first time you nail the throttle and your main jets are partially or totally covered in ice your pistons pour out the exhaust and your done. been there dun that!nosboy said:Heet in the little YELLOW bottles.. (methanol) Heet in the red bottles is isopropyl alcohol.... No need to waste your money with todays fuel.. If you have WATER in your fuel,, it will FREEZE and turn into chunks of ice and will not harm your sled.. Water turns into a solid at 32 degrese F.
You 're right... Thanks for the info !!!9801srx said:that ain't all true! what about the guy that keeps their sled in a heated garage or when the temp is going above and below freezing .the chunks of ice melt and can then get sucked up and pumped in to the carbs and as you know these carbs have no water traps on them so the water sits there right around the main jet waiting for the temp to drop and refreezes then the next time you go for a ride the first time you nail the throttle and your main jets are partially or totally covered in ice your pistons pour out the exhaust and your done. been there dun that!
alswagg said:My Son and I, yesterday ran over 100 miles at or near WOT on pump fuel. The SXR oil is Yamalube. The Viper is running Klotz Interceptor. In the fuel I add Sta Bil Marine formula at every fill up. Stock jetting, Stock engines except for milled head on the SXR. I know we are running 10% ethonal. I would have thought if we were to have a problem it would have shown up. I think the stock jetting is rich enough to overcome the detonation problems and the extra oil lubes everthing real nice. Oh, the carb heaters were both on 100%. We were in deep snow basically the whole time. Al
