I'll let you know then!!!lol
I already called dibs on the 50/40 helixthunder66 said:Monster... if you throw in the towel I call dibs on all your trick parts and your avatar!![]()
bluemonster1 said:I'll let you know then!!!lol
hey blue finally set up my srx it pulls like a f-16 well it seem too i'm alone so ......
finish with a w-w-w 53.6 gram at 8600 rpm raising up too 8800
need someone to get at my side to get a verdict ..dreamometer show 120mph but i'm sure its far from there
hey blue what brand is your 51-43 helix
don't know,probably a stock Yamaha one..
bluemonster1 said:don't know,probably a stock Yamaha one..
ok did u try back the 8bu-10......i did try back the 8dn-20 those weight sucks doesnt pull hard ...mopar1rules
modsrx said:ok did u try back the 8bu-10......i did try back the 8dn-20 those weight sucks doesnt pull hard ...
yep, stock 8dn-20 weights suck for "pull" IMO. there is a noticable change in "pull", from 8bu's to 8dn's.
load them up enough and they will pull good.
bluemonster1 said:load them up enough and they will pull good.
they will pull but not like my other set of weight .............
mopar1rules
even loaded they don't pull like 8bu's.
never try those 8bu's someday i guess i will .............
when it gets colder out,I will test them again..may be a while only.For time being the 8dn's loaded up 4.5/5.4g seem to get the job done.RPM's are on target.
On a scale of greatest to worst what do you guys think/know pulls the hardest out of the Yammie weights that we use. 8DN's, 89a-10's, 8BU's etc???
it is so hard to say.Every sled is different,every rider weighs different.There is hard pack snow and there is ice,studs or no studs.So mant factors come into play.If you can reach that magic number of 8450-8500 and still pulling..keep that setup.
I'm only looking for a ballpark answer. Not exact numbers. More just seat of the pants results what you percive to be best to worst for pull???
8dn- are great weight for trail riding .....the other are very aggresive from a dead spot .....need different helix to make them work
YAMMIEGOD3:16
8BU-00 '' PULL '' THE HARDEST. NOTHING CLOSE. BUT 8BU-10 ARE FASTER AND WILL RUN A WAY BETTER TOP SPEED. 3:16 (yammie tony)
YAMMIEGOD3:16 said:8BU-00 '' PULL '' THE HARDEST. NOTHING CLOSE. BUT 8BU-10 ARE FASTER AND WILL RUN A WAY BETTER TOP SPEED. 3:16 (yammie tony)
I wonder why the current world record srx speed run doesnt run 8bu-10s??, somehow they are going even faster with some other oem yamaha weight..............hmmmm
mrviper700 said:I wonder why the current world record srx speed run doesnt run 8bu-10s??, somehow they are going even faster with some other oem yamaha weight..............hmmmm![]()
loll funny what type weight they used for it
mattyg1405
i get so confused with this clutching stuff... why does my stock set-up always pull 8500 rpm's??? on grass, snow ,ice anything...
whats in an 01 srx stock??
