i'm back on track
modsrx
canada,qc
sled is running back with a new crank cylinder piston ............hope that sled will pull like hummmmmmmmmmmmm not like a train lolll
Good you have it running again!
Did you check and clean or remove the fuel screens under the float bowl needle seat? They can cause mysterious and repeat engine damage. I have removed them on all my sleds so I don't have to worry about them plugging up and I just rely on the fuel tank filter like every other sled manufacturer does.
JM.02c
Bob
JM.02c
Bob
yeah thnx for the input ..the oil cable was way out of spec and crank bearing failed ...ill go for a little test tomorow with the 165 main jet ...not sure how ritch it will be ...better be ritch than seize..thnx again for the jet ;)!
rich......lol..you got lots of money at that richness you will be burning a gallon of gas in about 10 minutes....you could perhaps get 2 -3 miles per gallon..not bad...lol
mod it if ot makes u feel better , i roasted a crank today broken rod and i cylinder piston ,,,,hhhhhhhhhhaaaaaaaaaaaaaaaaa
ooh well
going apex soon !!!!!!
well i was running 160 blue for 2 season and the sled is awsome on gaz ..we did some minor change to the motor so i wanna keep safe for now loll
ooh well
yeah i would love to jump on a apex turbo or supercharge ;)! ..sucks i did the same cylinder rod and piston all fry
A few years back, I was having to jet my SRX with jets as big as 160s and up. I always thought it shouldn't need such large mains and jetting it larger even to 165s seemed to have little effect on the way it ran. I decided to install larger Q-8 needle jets and then the sled was so rich at full throttle I had to jet it way down to 155s to get it to run properly!
Once I established that my sled was lean on the needle jet/needles I then went back to the stock Q-6s but have the needles on the 4th clip and my jetting is in the 155 - 158.8 range.
Worked for me!
Bob
Worked for me!
Bob
I WAS THINKING EXACTLY THAT THE 02 IS THE SLEIGH PULLER AND ITS GEARED DOWN , PILOTS UP ONE AND STOCK JETTING , BUT I TOOK HER FOR A RIDE WITHOUT THE SLEIGH AT MINUS 21C , MELTED THE MAG SIDE AND THEN CENTER ROD LET GO ? ...LOL..... JUMPED ON THE 2000 AND STILL FOLLOWED THE PLAN , BUT I GOT TO TELL YA , CRUSHED BY AN APEX MOST OF THE DAY ......WELL .....ALL DAY ,I WAS LOOKING FOR HARD PACK JUST TO KEEP UP SOME .......
Worked for me!
Bob
i'm running on 4clip with 160 all accross ...i did try 158.8 but it didnt last long before a piston burn down ..so did get back at 160 and never had any issue with burn piston :dunno:
You obviously are moving more air then my engine...I put the 162.5s in the mail so they should be there within a week.
Bob
Bob
thnx bob hope to get them soon soon ...ready for a little test drive today so ill get back later ;)!
did a little ride today with the 165 main jet ....sled really pulllllllllllllllllll hard so fun now ..a little ritch on cylinder 2 and 3 but right on target for cylinder 1 ...fun fun fun i love the pull of the srx
i didnt do wide open for long run ..i want that sled for ride now no more burn down loll
dammit motor need to be cured again ........a power valve broke in two peace and fall into a cylinder grrrrrrrrrrrrrrrrrrrrrrrrrr..sounds like i'm going for stroke soon soon lolll
damn thats bad luck. I can hear the sound of a thumper in my future as well. just need the money lol!
mod..what the hell are you doin???? man you better find another hobby I think..got pics of that..that would be cool to see a PV in cylinder....another $500 to spend I guess..guess u don't want that helix now..do you???
