sideshowBob said:Good you have it running again!
Did you check and clean or remove the fuel screens under the float bowl needle seat? They can cause mysterious and repeat engine damage. I have removed them on all my sleds so I don't have to worry about them plugging up and I just rely on the fuel tank filter like every other sled manufacturer does.
JM.02c
Bob
harness racer said:mod it if ot makes u feel better , i roasted a crank today broken rod and i cylinder piston ,,,,hhhhhhhhhhaaaaaaaaaaaaaaaaa
ooh well
going apex soon !!!!!!
sideshowBob said:A few years back, I was having to jet my SRX with jets as big as 160s and up. I always thought it shouldn't need such large mains and jetting it larger even to 165s seemed to have little effect on the way it ran. I decided to install larger Q-8 needle jets and then the sled was so rich at full throttle I had to jet it way down to 155s to get it to run properly!
Once I established that my sled was lean on the needle jet/needles I then went back to the stock Q-6s but have the needles on the 4th clip and my jetting is in the 155 - 158.8 range.
Worked for me!
Bob
Worked for me!
Bob
modsrx said:i'm running on 4clip with 160 all accross ...i did try 158.8 but it didnt last long before a piston burn down ..so did get back at 160 and never had any issue with burn piston![]()
sideshowBob said:You obviously are moving more air then my engine...I put the 162.5s in the mail so they should be there within a week.
Bob
