Ok I copied this from other posts which makes me more confused. What is RX440??? The one posts states there was a variety of prefix's in 76?? Since the last 3 digits of the chassis is 538 and the engine is 660 could it be original? the heads and jugs are 8F2
1974 GPX 338 SX-338
1974 GPX 433 SX-433
1975 GPX 338 SX-338
1975 GPX 433 SX-433
1976 SRX 340 RX-338/340
1976 SRX 440 RX-433
1977 SRX 440 RX-433
1978 SRX 440 RT-439
1978 SSR 440 RX-439
1979 SRX 440 RT-439
1980 SRX 440 RT-439
1981 SRX 440 RT-437
1982 SRX 500 RT-500
DEAN, THATS CORRECT. WHAT YA HAVE IS A 78 OR 79 LOWER CASE. NOW WHAT I WAS GETTING AT WAS IS THE CRANKSHAFT THERE WITH CASE. AFEW THINGS TOO REMEMBER. IN 1978 YAMAHA WENT TO LARGER CRANK RODS, LARGER WRIST PINS, AND DON,T FORGET THE LARGER STUD BOLTS. ALSO, IN 1978, YAMAHA ADDED GROMITS TO THE RECOIL AND THE UPDATED CRANK BALANCER TO HELP WITH HIGH RPM VIBERATION. THIS KIT WAS ALSO AVAILABLE IN 1979. NOW, IN 1980, THE VIBERATION PROBLEM WAS OVER BECAUSE THE CRANKSHAFT WAS ACTUALLY ALITTLE DEFFERENT BECAUSE THE OIL INJECTION PUMP DROVE OFF IT. YAMAHA THAN WENT BACK TO STANDARD RECOIL HOUSEING LIKE THE 76/77. ALSO, REMEBER IF YA SEE A 80, LOOK AT THE HOUSEING BEHING THE RECOIL. YOU WILL SEE THE COIL BRACKET THAT WAS USED ON THE 76 AND 77 SRX. ONLY THING IS YAMAHA MOUNTED COIL ON AIR BOX. ALTTLE BIT OF INFO FOR YA !! 3:16 (tony)
deanosmod 03-25-2006 12:59 PM
Now everthings coming togerther. I have a 79 with that housing. One more question. In 76 they had two different numbers for each motor? RX 338, RX 340, RX 433 and RX 440. WHY? I thought I knew everything about these girls years ago. It started 22 years ago and I'm still learning. Bought my first 80 srx in 1984 and was racing against a 77 and got my butt kicked at the end of the race day in the final. I bought that 77 two weeks later. Thanks for your help Tony and stop by some time. I'm right on your way going up north. Dean-o
YAMMIEGOD3:16 03-25-2006 03:46 PM
DEAN, MATTER OF FACT WAS GONNA HEAD TO THE MOOSE TODAY BUT DECIDED I JUST COULD NOT MAKE IT BECAUSE OF PLAINS TONIGHT. IF I LIVED WHERE YOU WERE, WOW!! I BE THERE EVERY WEEKEND lol !! ANYWAYS, TO TELL YA THE TRUTH, I ALSO HAVE SEEN THOSE DEFFERENT ENGINE NUMBERS. I SEEN THAT ALOT ESPECIALLY ON THE 76 340 SRX. IF YOU REMEBER IN THE YAMAHA SERVICE MANUALS, YAMAHA WOULD TELL YA THE NUMBERS MIGHT BE OFF BY AFEW. ANYWAYS DUDE, HOOK UP WITH MARK AND I THIS SUMMER AY AFEW SHOWS. WE ALWAYS BRING A COOLER FULL OF POPS!!! 3:16 (tony)
