Update!
So, I haven't gotten my gears yet
Not sure when I'll get them, but oh well - gives me time to work on the clutches!
I finally got around to taking apart my secondary clutches, and have the following:
Secondary Clutch #1
This clutch has two shims installed in the middle, for a wider belt, so Im going to keep that for use on my 89L belt.
The helix is slightly machined at the tip of the ramp, and the back of it seems to have been machined as well. (See Pics)
It has a black spring with a white tip.
This clutch spring was positioned in B-3.
This clutch performs well, and is what I currently use.
Secondary Clutch #2
This clutch had no shims installed in the middle.
The helix is stock, not machined in any way.
The spring is black, with a pink tip.
Setting on this was A-2
I Noticed the black/white spring seems to be longer than the black/pink spring - not sure what would change if I used one or the other?
here are some pics...
This is a pic of the machines helixes
This is the back of the helixes, why would one be deeper than the other???
Here are the springs - is it just me, or does the black/white look longer??? Or is it perhaps less tired???
Any recommendations?
I was thinking,
Spring in A-2 (As per Lasse's recommendations)
Black/White spring
Non-machined Helix
