sideshowBob said:SRX work...
Removed all suspension components front and rear and totally disassembled them.
Replacing all bushings, bearings ,sliders, painting all suspension components that need it ect.
Decided to install Fox air shocks on front end as well as rear suspension shock with nextech adjustable reservoirs all around....should save approx 10lbs...still trying to lighten up this beast!
Next on the list is replacement of all seals and bearings in the chaincase, jackshaft, and drive shaft...then its on to installing new motor mounts....it never ends!
I love it...lol, Hobbys should never end
Bob it ends when your 6 feet under...but don't know if I can keep on wrenching the sleds in a few more years.Long travel on SRX will help me a bit.Just feeling it these days more with the back and all...
I went about 185 km/h with the sled today.
That's about 115 mph.
devinzz1
norwegian said:I went about 185 km/h with the sled today.
mine tops out at 175kmh? what sled?
if you put triple pipes on your sled you'll pass that 02 SRX then...devinzz1 said:mine tops out at 175kmh? what sled?
that would be 111 mph on speedo..but actually only about 100mph in reality..norwegian said:I went about 185 km/h with the sled today.
Do your math bluemonster1
185/1,609= 114,978 mph.
I know it's not as fast in reality. I will check later what the gps on the contour says.
I go by .6 times 185 equals 111..we are slower here..lmao and safer to.....lol
man,using your formula..my SXR600 really goes fast then...I am happy with that...just bugging you anyways..let me know when you hit 130 mph on that SRX..
Just changed the Temp Sensor on the Apex Super Charger and the leaky Thermostat Gasket... hope thats the end of the leaks
staggs65
moved mine around in the garage, not exciting I know
02 SRX 700devinzz1 said:mine tops out at 175kmh? what sled?
super1c
Super Moderator
Took my wifes viper inner bumper support out. Not easy getting at those bolts tucked away inside the front bulk head. Bent way out of wack, no wonder her hood never closed right after that fender bender. Got to get elizabeths out yet too, as i knew that one was bent from the start. Somthing to do tomorrow.
super1c
Super Moderator
MrSled said:Swept out my trailer, put 2 sleds away and installed my new Frig Wrap
Now i like that!!! Where do you get those?
devinzz1
"get you you dick beaters off my quad" thats it! im getting 8! thanks for showing me this site mr. sled! and by de way... i dont know if its the angle of the pic be she looks a little disproportionate. ( her "tits" are as big as her thighs )
all fake of course!!!
did nothin to my sleds today...
dsc577
Went threw my TSS,swapped front lift bar,cleaned and painted belly pan,drained fogging oil from pipe and lost a bunch more screws
